Old 03-17-2007, 10:19 AM   #1
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
*Help* What is this?
Alright... I can read, so I have an idea... But can someone Explain to me, in layman's terms, What this thing is and what it does?
http://www.trdparts.jp/english/list_race-mis_ncp13.html
Thank you,
Nutzoids is offline   Reply With Quote
Old 03-17-2007, 11:04 AM   #2
ChinoCharles
Drives: LB
Its what you get when you're bored of working on the engine.
Old 03-17-2007, 11:34 AM   #3
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
As echo_hrs said, it changes the gear ratios in the tranny for different driving situations. Those gear sets are probably made of a stronger alloy as well so they'll handle more HP than the stock gears.
Dragonacc is offline   Reply With Quote
Old 03-17-2007, 12:04 PM   #4
Nutzoids
Nutzoids's Avatar
So this thing would be good after I do whatever modifications I have planned... Turbo, exhaust and all... Right?
Old 03-17-2007, 12:09 PM   #5
Possibly... It depends how you want to balance your top speed vs acceleration for a given engine power.
With a stock engine, if you want to go racing on a normal track or auto-x, you don't expect to be able to reach 100MPH at any point. So, it makes sense to have shorter gears, as you can accelerate faster.
As you build up your engine's power, you will find that with the stock gearing, you will reach the car's maximal speed pretty fast. So either you can keep things this way, or you can go with a longer gearing to get you extra top speed at the expense of acceleration.
My advice, go get Gran Turismo 4 or Forza motorsport if you have an xbox, buy a car, then a fully adjustable gearbox, and have a play around with the final gear ratio settings, see how it affects the car
Old 03-17-2007, 01:23 PM   #6
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
E-tuning 101
jdubau55 is offline   Reply With Quote
Old 03-17-2007, 01:27 PM   #7
Nutzoids
Nutzoids's Avatar
I love it!
Old 03-17-2007, 08:43 PM   #8
heck that's how I learned most of the limited things I know
Old 03-18-2007, 12:45 PM   #9
jdubau55
I def put in GT and bought the Vitz and hooked it up just to see the potential. I won 5000 credits
