Old 02-26-2013, 02:28 PM   #1
esse10
Drives: 2009 yaris 2 door
OBDII
Hello folks , I am new here and was wondering if there is a way to read the coolant temperature and RPM using an Iphone??? what program to use and if the yaris works with the ELM32 OBD 2 TESTER. Any help is appreciated.
thanks
julian
Old 02-26-2013, 02:35 PM   #2
The Yaris is OBDII compliant over CAN BUS and coolant temp and RPM are standard OBDII PIDs, so any hardware/software combo that supports OBDII via CAN Bus will work. With the iphone you are somewhat limited because the iphone doesn't support the bluetooth serial port mode, required by most of the bluetooth OBDII interfaces. So, for the iphone you typically need a more expensive WiFi based OBDII device.
Old 02-26-2013, 02:36 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
just type that into amazon. I did and it came up with quite a few things for what you are asking.
you could also just get an ultragauge and it is right there.
***for reference***
http://www.amazon.com/IOBD2-Wireless...e+obd2+scanner
http://ultra-gauge.com/ultragauge/index.htm
Old 02-27-2013, 08:29 AM   #4
esse10
update
Hey thanks folks I got my answer yesterday. The elm32 obd2 tester does work with apple's program REV2, and an iphone of course. A little pricey but worth it i think. Also tested the program FUZZYCAR and it worked also just not as many bells & whistles as the REV program. Fuzzycar is only $5 bucks at the apple's app store.
good luck folks.......
Location of the OBDII port sickaroll DIY / Maintenance / Service 7 04-10-2017 10:35 PM
OBDII dongle to connect to rev app for iphone zachryboles Performance Modifications 1 12-01-2010 04:05 PM
Help - OBDII error code "system running lean" Gazdaman DIY / Maintenance / Service 4 05-14-2009 12:34 PM
What sensors can be read using OBDII on 2007 Yaris? thebasemetn1 DIY / Maintenance / Service 7 01-11-2009 05:44 AM
Bluetooth OBDII WolfWings In Car Entertainment + Electronics (audio / video / alarm) 5 09-01-2007 05:44 PM
