Old 02-27-2013, 02:34 AM   #1
A1phazu1u
A1phazu1u's Avatar
Drives: Black 07 Toyota Yaris Sedan
Yaris Steering wheel Swap with Controls.
So I've been looking into swapping my steering wheel with one that has controls on it and i've recently picked up a 07 camry se wheel with audio and handsfree controls. Next step is to get a new clock spring that supports the extra wiring which is on the way.
What i need help with is finding the wiring that goes from the clock spring to the head unit. the rest of the wiring should be easy, i just can't seem to find that cable. If anyone can find one or a part number i would greatly appreciate it.
Pics of project soon, once i get the parts in. Thanks in Advance.
A1phazu1u is offline   Reply With Quote
Old 02-27-2013, 07:32 AM   #2
The wiring from the clockspring to the headunit is part of the dash harness, so you would have to track down the entire dash harness of the vehicle you use the clockspring from. Or, you can just purchase the connector shells and buy the "repair terminals" to populate them. Toyota charges $12 to $20 per connector pin, but I stock them for a whole lot less, if you go that route.
Old 02-27-2013, 02:11 PM   #3
A1phazu1u
A1phazu1u's Avatar
I guess ill purchase them from you, ill contact you when I receive my clock spring. Thanks again Scott.
steering wheel swap over nickos Cosmetic Modifications (Exterior/Interior) 8 08-04-2011 07:55 AM
Steering wheel controls + Eclipse HU mick.wheelz In Car Entertainment + Electronics (audio / video / alarm) 1 05-29-2010 11:03 AM
