Old 02-27-2013, 05:44 PM   #1
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
Rigid Collar
http://www.youtube.com/watch?v=zWyUD...layer_embedded
These seem pretty cool.
(dick measuring info goes here)
aeipee13 is offline   Reply With Quote
Old 02-27-2013, 09:52 PM   #2
Viperoni
Drives: 2005 Toyota Echo
The statement that you can't have "accurate geometry setup" because of the enlargened bolt hole is flawed: who's to say that their collars will place the subframe in the "correct" place?
I also don't buy the "reduced vertical motion" comparison for a second. The only way you'd get that is if the subframe was loose to begin with.
The difference in steering feedback can be explained by a beneficial change in alignment... it sounds like the collars in the demo vehicle added some positive caster.
2006 Saturn Ion Redline
Old 02-28-2013, 07:34 AM   #3
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Yeah, I call bullshit too.
Doing bushings like that takes away any chance of correcting manufacturing inaccuracies that could be adjusted out by having the oversized holes. This way, you are stuck with crooked parts.
Old 02-28-2013, 01:56 PM   #4
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Originally Posted by aeipee13 View Post
$300. for a set, Not cheap! But it makes sense to me.
Why not buy a collar for a couple of bucks, seems like it would do the same thing.
UberSilver is offline   Reply With Quote
Old 02-28-2013, 04:25 PM   #5
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
What up Aeipee? Where have u been?
marlondog is offline   Reply With Quote
Old 02-28-2013, 06:42 PM   #6
It does make sense, but I wouldn't use aluminum inserts. Thicker steel bolts are used on some cars - there is a kit available now for the BRZ/FR-S
Old 02-28-2013, 09:52 PM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i'd buy em...
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Leatherette shifter collar jambo101 DIY / Maintenance / Service 6 04-19-2010 09:38 AM
Blue collar Yaris Bretsuaz Off-topic / Other Cars / Everything else Discussions 7 02-06-2007 02:58 PM
