Old 02-28-2013, 05:19 PM   #1
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Has something changed? Oils...
Took my car in for its oil change last weekend to the dealer, and when I said synthetic please they asked if I wanted 0w20... I didn't think my Yaris (2009) was one of those approved to use the 0w20 stuff?
I have no problems using it next time, but I have always ran the recommended 5w20. Of course its just out of warranty now as well.
SKurj is offline   Reply With Quote
Old 02-28-2013, 08:47 PM   #2
brg88tx
Drives: 07 Yaris Sedan, Auto
i think they just keep using thinner and thinner for better mpg. i just bought a 2011 highlander 4 cylinder and the oil cap says 0w20
brg88tx is offline   Reply With Quote
Old 02-28-2013, 10:18 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
It does help gas mileage, but the oil quality is actually better. Even 7 years ago no one would have thought about using these oil grades because the oil would break down far to fast to be useful.
Now they are still extremely thin, but they are actually strong enough to last actually being used in cars.
Colin Chapman disciple
Old 03-01-2013, 03:50 AM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The lower viscosity number only applies when the engine is cold and during warm up, once the engine temp is up to operating temperature the higher oil viscosity number is predominant.
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Have Yaris will travel..
Old 03-01-2013, 07:00 AM   #5
SKurj
Well te question about has something changed relates directly to 0w20 was not approved before so its good that it is now. Curious if it makes any difference. I doubt it seeing as most of the time the engine is in the higher temp range.
Old 03-01-2013, 07:17 AM   #6
why?
why?'s Avatar
Drives: Yaris LB
even at the higher temp range, the oil is thinner. That means better gas mileage.
Old 03-01-2013, 01:23 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I believe that Hersey had started a thread a couple years ago about the formal notice from Toyota about the change, but it might not have been him.
Old 03-01-2013, 02:07 PM   #8
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
I think you are right and he posted this PDF file:
http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja
2007 LB W/Cold Wx Package
DMZ is offline   Reply With Quote
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 05:18 PM
Amsoil XL 5W-20 Sodium Duck DIY / Maintenance / Service 15 03-04-2009 12:19 PM
