#1 |
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
boomslang, ECU connectors......CTSCott
Hi,
can anyone provide me with more info about the ECU connector, pins part # etc. Scott do you have the part number for the connector used in the ECU? Pins? Are they crimped or soldered? Where to source them from? Proprietary? I know I can look at it in my car but wonder if anyone here has done so and have the info . MOD please move if this should be in another section. |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I was talking to Jeff@MI about these the other day. He said that the Yaris ECU connectors are very expensive and difficult to find. If you want one, probably your best bet is to go to a junk yard and get one there.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#3 | |
^ correct.
![]() Pinouts of the ECU have been posted before. I have a couple of downloads on my forums in the Download section.
#4 | |
Will definitely look at the one in the car and take pics as well. |
#5 |
From Toyota the female pins (82998-24250, 82998-24400, and 82998-12590) are about $20 each (and you need a lot of them) and the female connector (90980-12399) is about $25. My recommendation on the female side is to purchase an engine harness off eBay or from a junkyard ($80 to $200). The nicest thing about using an existing harness is that all of the wires are the OEM colors, and all of the crimps are already done.
You can not purchase the male side connector and pins, as it is a PCB mounted connector, so you have to harvest it from an ECM. It is not ideal, as you have to then solder and heatshrink the connectors PCB pins, which are intended to be rigidly mounted. The common failure mode for a boomslang or a DIY version is to have the solder joint fail, or the PCB pin fail from fatigue. The best way around this it to fully pot the back side of the connector, beyond the PCB pins. Take a look at this article that I wrote for the Micro Image forum on building your own: http://www.microimageonline.com/foru...o-expensive%29
#6 | |
![]() ![]() ![]() Or.... I can edit this post and ask you for a closeup pic of the pins and connectors if you have them on hand. Last edited by hw6515; 03-08-2013 at 08:41 AM. |
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 02:36 PM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
