Old 03-18-2013, 12:26 AM   #1
Yarflana
Drives: 2008 Base Model
adjusted handbrake...woohoo down to 1 click!
Well, adjusted the much needed hand brake (at the rear wheels...not the handle itself) and after putting on the stainless lines, bleeding and handbrake adjustment, the brakes, even without a pad or shoe change yet (coming next month), the brakes are better than in a long time.
Just wanted to say thanks to those who put up the DIY on this and chimed in to make those little steps worthwhile to do it easily and without fail.
Pat
Yarflana is offline   Reply With Quote
Old 03-18-2013, 01:04 AM   #2
Wait, it only takes one click to fully engage the handbrake? I think that's bad. Isn't it supposed to be 3-4 clicks at minimum or else you'll constantly be riding the shoes?
Old 03-18-2013, 10:32 AM   #3
Yarflana
Good point, but not on mine. Before riding off into the sunset, I tested the rear wheel freedom after actuating the hand brake after adjustment and all was fine. I think 3-4 clicks is just a "stock" adjustment point, but you can actually get it tighter without rubbing.
Old 03-18-2013, 02:18 PM   #4
Ah, I see. I didn't want to take the chance, so always hovered at 4-5 clicks
Old 03-18-2013, 02:24 PM   #5
Yarflana
Yeah when I work on the brakes, I always give it a good workout before I put the tires back on and do a test drive.
After we bled the brakes the other day after changing to the stainless lines, I jammed on that pedal hard about 20 times to check for leaks and other stuff...you just cannot afford a failure on the road due to shadetree mechanic negligence.
Old 03-18-2013, 02:35 PM   #6
+1. Brakes are very important.
Old 03-18-2013, 08:02 PM   #7
nookandcrannycar
^^^^^This. I took my car to a local shop to have the brakes checked last year. My pads were only 20% worn. The sound war coming from the rear brakes. Just dust build up that needed cleaning out, and they also made the hand brake adjustment you speak of. When I picked the car up, the hand brake was also at 1 click, and there was no rubbing.
Old 03-18-2013, 08:59 PM   #8
Might adjust my brakes even more then. :)
Old 03-18-2013, 09:47 PM   #9
Yarflana
After putting on the stainless lines, bleeding the system really good and tightening the handbrake, the pedal travel is 50% less, the feel is twice as firm as before and this all before I even change pads, shoes, drums, and discs.
I guess you get used to some pretty crappy stuff after 100k and no adjustments.
Old 03-18-2013, 10:36 PM   #10
I just recently changed my break fluid for the first time with Valvoline DOT3/4 fluid. I noticed less pedal travel to brake, at the same time, I have no clue why my car doesn't nose dive when braking anymore. Very odd feeling, and not expected, since it doesn't feel like I'm slowing down, but I see my speed falling.
I've been constantly adjusting the rear drums to hover around the 4-5 clicks I said earlier. I'll probably readjust them down to 2 clicks on Friday after washing the car.
I changed my front pads to the Carbotech street pads a few years ago. Much better bite than stock, but more noisy and dusty (easier to clean off the not-so-abrasive dust of the Carbotech pads) than the stock pads.
Help with Loose Handbrake Roth5150 DIY / Maintenance / Service 3 09-14-2011 10:56 AM
Handbrake Loose Roth5150 General Yaris / Vitz Discussion 1 09-12-2011 09:03 PM
Rear Brake issues at the track? alway need to be adjusted how to fix? TRD.RiC Tracking, Racing, Auto-X Forum 13 08-23-2011 08:29 PM
Auto trans : Drive to Park + Handbrake : was not in park... Maxh91 General Yaris / Vitz Discussion 7 06-11-2009 06:37 PM
Rotated tires and adjusted rear brakes today PICS auxmike DIY / Maintenance / Service 11 11-14-2008 08:24 AM
