Old 03-22-2013, 08:05 PM   #1
NEexpat
Drives: 2009, auto, 4dr LB
About to call Bravo Sierra
Has anyone here had any luck adjusting their Hand/E brake by driving in reverse and braking, or hard braking?
I have tried this a couple times, no difference, at least none that I have noticed. On a Toyota forum they say you really have to slam on the brakes to get them to self adjust.
NEexpat is offline   Reply With Quote
Old 03-22-2013, 09:12 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
never heard of this
Old 03-23-2013, 02:54 AM   #3
bronsin
bronsin's Avatar
As a former car mechanic I saw a lot of self adjusting brakes that didnt work as advertised.
Old 03-23-2013, 03:12 AM   #4
2005rs
Drives: 2005 Echo Rs
The adjusters in the rear drums adjust shoe clearance, not ebrake cable tension
2005rs is offline   Reply With Quote
Old 03-23-2013, 08:27 AM   #5
bronsin
bronsin's Avatar
Right.
But my point was you REALLY want to hand adjust your rear brakes at the wheel or a least check them once a year or so.
Old 03-23-2013, 08:47 PM   #6
nookandcrannycar
Right.
I imagine this is why (when I took my car in last year re the noise the brakes were making) they cleaned out all the brake dust AND adjusted the cable (tight enough to pull past no more than one click when the car was ready). Thirty some odd dollars total for both.
Old 03-23-2013, 08:58 PM   #7
Yarflana
Drives: 2008 Base Model
I wouldn't mess with the ole' "back up my Y and adjust the e-brake"...just isn't the same, if it does anything at all.
I will tell you that I adjusted my e-brake at the drums and got that bugger snug down to 1 click.
Just use the M8x1.25 two inch bolt in both holes after removing the wheels to break the drum loose (you can put WD40 on the bolts to ensure you don't get excess in the drum area).
Then just use a small screwdriver to move the adjuster up (put the screwdriver against the hub and push it down to move the adjuster up about 2-3 clicks at a time, then put test the fit by putting the drum back on just enough to see if it clears the shoes.
When it gets to where putting the drum on rubs the shoes, you are done and can reassemble. I assume you know how to put on and take off the wheels. Also, this makes a good time to go ahead and rotate your tires, if you like while you have the jack and stands out.
I didn't clean out the area or anything and mine had 100k miles on them. I will do all that when I replace the drums and shoes later next month.
That is really it and thanks to a DIY posted on this forum a while back.
Yarflana is offline   Reply With Quote
Old 05-30-2013, 10:51 PM   #8
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Let the car roll down a slight decline and depress the brake pedal quite hard....do this a couple of times....that is how it is "suppose" to assist adjusting the rear drum brakes.As the folks said above,it is much better to adjust with the drum off. Don't forget the e-brake handle has an adjustment also....you have to remove the plastic around the lever to gain access to the nut.
frog13 is offline   Reply With Quote
Quad-State Roll Call? lol Zefoxe NY / NJ/ CT / PA 35 10-09-2012 11:46 AM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
Castle Bravo - plasma beauty GeneW Off-topic / Other Cars / Everything else Discussions 6 04-18-2009 09:51 AM
I am going to call Toyota FEINT General Yaris / Vitz Discussion 4 03-25-2009 08:38 PM
