Old 03-27-2013, 02:40 PM   #1
Gladmo2
Drives: 2008 Yaris T2
Fitting double din head unit
Hey all,
In need of a bit of help - I have a 2008 Toyota Yaris (UK) and I am planning on replacing the head unit.
I currently have a W58824 and I have ordered a Parrot Asteroid Smart. (double din)
I have also purchased this: (can't remember model number)
Could anyone tell me what else I would need such as Wiring harnesses and ISO mounts?
I am a complete beginner at this, but I would like to learn hence why I am trying this for myself.
Thanks!
Gladmo2 is offline   Reply With Quote
Old 03-27-2013, 05:15 PM   #2
If your new radio is double DIN and you ordered the 180mm opening trim, rather than the standard Toyota 200mm opening one, then you will not need the trim kit to fill the gap on either side.
For the wiring harness, you can pick up a generic Toyota one on ebay for $5 US or less, or the Metra 70-1761.
Old 03-27-2013, 05:52 PM   #3
Gladmo2
That's absolutely great!
Thanks for your help CTScott! :)
Old 03-27-2013, 06:02 PM   #4
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Any idea why I would loose power to my center cluster dimmer knob and my a/c control knobs. I installed an aftermarket single din. Got all the right stuff. My dimmer doesn't work. And the lights for the a/c knobs don't light up anymore...
yariSB86 is offline   Reply With Quote
Old 03-27-2013, 06:05 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
possibly a bad harness?
Old 03-27-2013, 06:58 PM   #6
It sounds like the PANEL1 fuse in the under dash fuse panel is popped.
Old 03-27-2013, 09:07 PM   #7
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Did you disconnect your Ground battery terminal from the battery before attempting install ?
Old 03-28-2013, 12:16 AM   #8
yariSB86
yariSB86's Avatar
I did disconnect the battery. Ill check the fuses tomorrow.
Old 03-29-2013, 07:57 PM   #9
yariSB86
yariSB86's Avatar
Where can I find a diagram of that fuse panel?
din, double, fitting, head, unit
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 02:13 PM
reasonably priced double din head unit BrazdonW In Car Entertainment + Electronics (audio / video / alarm) 4 11-12-2010 04:47 AM
For sale Pioneer double din head unit!! 2009BBPliftback Items for Sale by private party 12 07-10-2009 12:21 AM
Sony XAVW1 double din head unit Julz In Car Entertainment + Electronics (audio / video / alarm) 4 09-09-2007 09:27 PM
