Old 03-30-2013, 04:29 PM   #1
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Fuses?
I have no clue what I'm looking at in the in dash fuse panel.
My a/c control knob lights and center cluster dimmer switch no longer work.
What do I need to check/replace to fix this?
I have looked EVERYWHERE to find a diagram labeling what fuse and what plug does what with no avail.
Any and all help is greatly appreciated!
Thanks in advance guys.
-B
p.s. this failure is a result of installation of an aftermarket head unit. its a JVC single DIN headunit connected with a metra wiring harness.
yariSB86 is offline   Reply With Quote
Old 03-30-2013, 05:07 PM   #2
Check the panel1 fuse in the panel that is under the bottom of the dash, by the hood release lever.
Old 03-30-2013, 05:18 PM   #3
yariSB86
yariSB86's Avatar
That's what I see. which fuse is panel1? nothing I see is labeled that.
Old 03-30-2013, 05:36 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
check the plastic piece you removed to get to the fuse panel, there's a diagram on the back with labels.
Old 03-30-2013, 05:39 PM   #5
You are in the wrong place. Look under the bottom of there.
Old 03-30-2013, 06:54 PM   #6
yariSB86
yariSB86's Avatar
Thanks CTScott! I checked the panel1 fuse. still good. Any other ideas?
Old 03-30-2013, 06:55 PM   #7
yariSB86
yariSB86's Avatar
could I have missed something being plugged into the metra harness for the headunit?
Old 03-30-2013, 06:59 PM   #8
Check the MET and GAUGE fuses as well. With the Metra harness the most likely issue would be popping a fuse if you connected something incorrectly or made the connections with the battery still connected and accidentally grounded something that should not have been.
Old 03-30-2013, 10:04 PM   #9
yariSB86
yariSB86's Avatar
MET and GAUGE fuses were intact.
Rechecked PANEL1, it was bad.
Replaced PANEL1, it blew.
I must have a ground somewhere behind my headunit or amp...ill check my wiring tomorrow.
Thanks for the help again CTScott.
Old 03-31-2013, 10:24 PM   #10
yariSB86
yariSB86's Avatar
So I checked all my wiring. Everything seems in order. I went ahead and respliced my head unit harness just incase. But without a spare 7.5 fuse I wont know for sure. Ill pick one up tomorrow morning when I leave work. Ill post when I install it.
Out of curiousity, I wanna know the functions of some fuses. dante2086 DIY / Maintenance / Service 0 05-29-2010 03:10 PM
Good source for the tiny, half-height OEM fuses? schleppy In Car Entertainment + Electronics (audio / video / alarm) 6 05-19-2009 04:55 PM
Replacement Fuses Meteorite_Marty DIY / Maintenance / Service 6 12-30-2008 04:15 AM
Amps and fuses TEHxFALLEN V1.2 In Car Entertainment + Electronics (audio / video / alarm) 12 11-18-2008 11:49 PM
blowing ear drums and poping fuses BlueFlash Southwest 5 05-29-2007 07:10 PM
