Old 03-31-2013, 04:48 PM   #1
Hoaph
Drives: 2007 Yaris 5dr Hatchback
Lubricate Door Locks...but how?
I imagine that this is a simple question...anyway, Toyota's service schedule has them lubricating the door locks every service...but how do they do this?
Are they taking the door panels off to do it? Or do they simply spray some lube into the part where the door contacts the body? ...or the keyhole? I should mention that I have automatic (electric) locks in my car (and only have keyholes on the driver's door).
Also, would it be okay to use white lithium grease?
Thanks everyone!
_______________
2007 5dr Yaris Hatchback 1.5L
BC, Canada
Hoaph is offline   Reply With Quote
Old 04-01-2013, 01:49 PM   #2
Geoff Peace
Drives: Yaris 1.33 litre 2011
Thanks everyone!
_______________
BC, Canada
The best lubricant for locks is powdered graphite, but it is messy. You need an aerosol of light oil containing teflon, specifically for locks. Grease is too thick, the tumblers will stick and the grease will attract dirt and grit which acts as an abrasive, not good! Oil will wash through taking out old lubricant and dirt. Push the rainwater shutter to one side with a small screwdriver and spray the oil in, A lot of grit is introduced into both door and ignition locks by dirty keys. Keep them clean.
Regards Geoff Peace
Geoff Peace is offline   Reply With Quote
Old 04-04-2013, 08:19 AM   #3
kc0rpm
Drives: 08 yaris sedan
I use a graphite spray. Works great.
kc0rpm is offline   Reply With Quote
Old 04-04-2013, 12:39 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Powder grafite for the door locks and silicon spray for the door hindges
Old 04-04-2013, 01:20 PM   #5
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
I use the dupont teflon silicone spray
http://www.amazon.com/Dupont-Multi-U...e+spray+dupont
pretty darn good stuff, lasts long too
B2FiNiTY is offline   Reply With Quote
Old 04-04-2013, 02:03 PM   #6
Kar98
Drives: 2011 Scion tC
Graphite spray. Squirt squirt.
Old 04-04-2013, 02:47 PM   #7
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Dry teflon spray.
UberSilver is offline   Reply With Quote
Old 04-04-2013, 03:53 PM   #8
YarisSedan
http://www.amazon.com/Panef-Corp-Pow...owder+graphite
this is the brand i keep in my tool box i usually sprinkle some on the key and insert it and turn it a couple of times. Careful when squeezing the tube a lot will come out usually i just tap it a few times. Works good for sticky zippers on your jacket as well
doors, locks, lube, lubrication
