Old 04-02-2013, 06:24 PM   #1
echo_maniac
Drives: blue 05 echo 3dr hb
wire speakers into 05 echo hb
Hey guys,
My echo only came with 2 dash mounted speakers, no speakers in the doors. I really want to put some in the doors but there's no place where I could run wires into them because there are no wires going in the door. Most cars have a plastic/rubber hose thing where wires run through, but I don't! How could I run wires in my door?
echo_maniac is offline   Reply With Quote
Old 04-02-2013, 06:28 PM   #2
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Take pictures. May have a plug there. Also take a pic of your doors
Old 04-03-2013, 07:48 PM   #3
echo_maniac
I have just found the factory hole for the wires. I think I'll be alright from here. But to you know if you can buy that plastic/rubber hose that covers the wires in between the door and the car?
Old 04-03-2013, 08:28 PM   #4
_S7V7N_
_S7V7N_'s Avatar
@CTScott would be the guy to ask
Old 04-03-2013, 09:01 PM   #5
echo_maniac
new problem: how do I wire the new speakers to the radio? man this is complicated.. lol
Old 04-03-2013, 09:41 PM   #6
_S7V7N_
_S7V7N_'s Avatar
I had a similiar situation. My Base model Yaris didn't come with a Radio. But it came with all the wiring and even Factory speakers.
You plan on replacing your Radio ?
Old 04-03-2013, 09:44 PM   #7
echo_maniac
Yes, I will definitely change my radio. I do have 2 dash speakers that I plan on changing as well.
Old 04-03-2013, 09:48 PM   #8
_S7V7N_
_S7V7N_'s Avatar
K that makes it easier using a radio harness.
Where you from ? Making sure you're in the US.
Old 04-03-2013, 09:49 PM   #9
echo_maniac
Canada actually
Old 04-03-2013, 09:52 PM   #10
_S7V7N_
_S7V7N_'s Avatar
Limited access to parts. Unless you order off ebay
Old 04-03-2013, 09:56 PM   #11
echo_maniac
I will probably order online, so shouldn't be that much of a problem
Old 04-03-2013, 10:00 PM   #12
_S7V7N_
_S7V7N_'s Avatar
http://www.yarisworld.com/forums/showthread.php?t=41812
Read that i believe it'll be the same harness. Let me double check when i get on a pc.
Old 04-03-2013, 10:05 PM   #13
echo_maniac
Alright yeah I think that's it. Thanks. Do you know if there's a thread that explains how to get power to your new speakers? I've been looking everywhere and I can't figure it out
Old 04-03-2013, 10:07 PM   #14
_S7V7N_
_S7V7N_'s Avatar
I can help you. Give me a bit.
Old 04-03-2013, 10:34 PM   #15
_S7V7N_
_S7V7N_'s Avatar
K lets start over.
Do you have a new headunit already or are you looking for one ?
Do you have Replacement speakers or you looking ?
Lets start there first. Are you willing to add an amp ? And bring your speakers to life.
4 inch speakers on the Dash
Hopefully 6.5 inch speaker holes on the doors. Won't know till you remove them.
Echo Harness : http://www.ebay.com/itm/TOYOTA-Echo-...-/260652122126
Old 04-04-2013, 06:02 AM   #16
echo_maniac
I haven't bought anything yet. As for the amp, if its not necessary I'd like to skip adding one
Old 04-04-2013, 08:02 PM   #17
echo_maniac
oh and I don't need top-of-the-line stuff either. Anything is better than my stock setup
Old 04-04-2013, 09:29 PM   #18
_S7V7N_
_S7V7N_'s Avatar
Do you need an amp? No. It will however make your speakers sound ten times better.
Is it going to be easy to install an Amp ? INstalling an amp is like riding a bike. It'll be difficult at first but after that it gets easier.
Okay let me know where you want to start and i can make suggestions. IN the end it'll be 100 percent your decision.
Headunit : Budget and what features. (bluetooth, usb, 3.5 mm adapter, etc...)
I'm taking an educated guess at your having 6.5 inch speaker holes in your doors. Best way to tell is if there's grills there already and you can remove the door to be certain.
Your dash speakers are 4 inch speakers.
If you're going to run these speakers off your headunit they will need a low RMS 35 watts RMS at the most. However if you change your mind in the future and want to add an amp then we run into problems. Like you said right now you don't have anything so something is better than nothing. I will start to put up a few speakers that will run off of the headunit power efficiently. Although you could run a 3 way set up with a component speaker system and your 4 inch dash speakers off a 4 channel amp.
doors, echo, speakers
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Scion XD LED mirror install pics aplenty enviri DIY / Maintenance / Service 76 07-21-2019 02:10 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
