Old 04-09-2013, 10:50 AM   #1
Starrbri
Drives: 2007 yaris sedan standard
Hole in carpet next to clutch
Hello,
It appears a hole has worn in my carpet, next to the clutch. Does anyone know of any floor mats that would cover this part of the carpet? Preferably all weather.
Thanks,
Starrbri
Starrbri is offline   Reply With Quote
Old 04-09-2013, 11:52 AM   #2
I have Weathertech mats in my blue Yaris and Lloyd mats in my red one. Both would cover that area.
Old 04-09-2013, 12:16 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Heh you can kinda see the permanent outline of your shoe.
Old 04-09-2013, 12:40 PM   #4
Starrbri
Thanks Scott, I went with the Weathertechs.
Old 04-09-2013, 02:11 PM   #5
Starrbri
Not my shoe. Just purchased this, 2007 40K miles. Not sure how it worn through with that few miles.
Old 04-09-2013, 02:54 PM   #6
The carpet is pretty thin. I think a couple good slips of the foot will start a tear, which will eventually become a hole. I know mine is starting to widen :(
Old 04-10-2013, 10:21 PM   #7
CoryM
Drives: 2009 5-door, 5-speed
My weathertechs cover there, but not where I rest my foot. I am planning on making an aluminum plate to go over it.
Old 04-11-2013, 03:39 AM   #8
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I bought Garms complete carpet for that exact reason, except mine is much much worse than the OP's.
-Type 07 FFL-
My odometer 03/11
Old 04-11-2013, 08:31 AM   #9
Starrbri
I guess with 400,000+ miles you really need some carpet protection.
Old 04-11-2013, 10:06 PM   #10
nookandcrannycar
Part of his cluster stopped working after that and he replaced it (so different odometer). He has over 530,000 miles now.
Old 04-11-2013, 10:11 PM   #11
nookandcrannycar
Can wear through quickly with the wrong shoe. My factory mats were fine until I bought some hiking boots last year. I quickly wore through the driver side mat. I took the mat out completely and realized that the mat had kept the clutch from working as smoothly as it could have for over 200,000 miles.
Old 04-12-2013, 01:01 AM   #12
YarisSedan
I wonder if you can get a piece of carpet that matches the color from a carpet store and glue it in place over. Something that's more heavy duty and blends well.
Old 04-12-2013, 08:44 AM   #13
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Mine is wearing too. Someday I plan on going to Pull-a-part and looking for a dead pedal from some other car to go there.
My old echo had one.
Old 04-12-2013, 11:39 AM   #14
YarisSedan
Maybe something similar to this.
Old 04-12-2013, 11:46 AM   #15
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
I have that exact same hole in my used yaris I just bought. Let me know if the mat you picked does a good job of covering the area! :) Pic please? Thanks!
Old 04-12-2013, 11:47 AM   #16
Flipper_1938
It needs to wrap around the corner where the wear happens.
Old 04-12-2013, 01:00 PM   #17
YarisSedan
Thats why i said similar, could try getting a aluminum plate that's thin so easily to manipulate and have it bend slightly over that area. Something that you could cut with tin snips and grind down with a dremel so it looks almost like it was supose to be there. That way it would be a permennt fix. Could even get it engraved afterwards for a personal touch.
Old 04-13-2013, 09:52 PM   #18
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
how about stripping the entire carpet out and buying those cool weathertech mats? I still need to do that.
Colin Chapman disciple
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Clutch question. Black_griffin6 Performance Modifications 6 04-04-2013 04:30 PM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
