Old 04-09-2013, 03:46 PM   #1
shaunsm_uk
Drives: Yaris 1.3
Help yaris won't start!
Hi all,
Hooefully someone can help, my other halfs 2002 yaris won't start after being parked for the weekend, it was running perfectly before, it cranks over no problem and have taken the plugs out and there's definitely fuel but no spark on all coils, I've checked all fuses and even swapped the EFI relay, there are no ECU codes showing up,
Not really sure what to try next, could it be the crank sensor, I don't want to go swapping parts as it could get expensive but without codes showing up I'm a bit at a loss, could a sensor go without showing a code?
Thanks in advance!
shaunsm_uk is offline   Reply With Quote
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
