Old 04-10-2013, 05:41 PM   #1
Melloreel
Drives: 08 3dr LB
08 cup holder removal?
I want to remove the cup holder "door" so I can clean all the previous owners coffemate out? I have the manual on disk, but it states only how to do it when removing dash? Does the door come off without removing glove boxes?
Also in the manual pic it is not clear if you pry out on the hinge or in?
Any thoughts?
Melloreel is offline   Reply With Quote
Old 04-10-2013, 05:43 PM   #2
bladesmith6
Drives: 2007 yaris HB
Open the holder there is a screw down in the bottom remove that, then you will have to pry the sides out from the dashboard pulling forward. It does take a good amount of force but it will come out.
bladesmith6 is offline   Reply With Quote
Old 04-10-2013, 05:57 PM   #3
Melloreel
Drives: 08 3dr LB
In the manual it looked as though that screw was to remove the air vent! And dash. Will give it a shot!
Do you pry out on arms?
Old 04-10-2013, 06:22 PM   #4
bladesmith6
yes i would try with fingers first or a plastic trim removal tool.
Old 04-22-2013, 03:16 AM   #5
nookandcrannycar
Ugh. Gross (IMO..but not gross for you to relay...just gross on the previous owner's part). I don't remember if your purchase was dealer/craigslist/ebay/other. If mr miles sees this, he'll probably have that reaction several times over (and other members as well).
Old 04-29-2013, 04:11 PM   #6
Melloreel
Drives: 08 3dr LB
Gross?
Then. They wouldn't want to see what I found under the seat, when I took them out
Old 04-29-2013, 04:15 PM   #7
Melloreel
Drives: 08 3dr LB
Ok! On a serious note. I have replaced the water pump, installed cruise control. But I cant get the @&$&@& cup holder out. Anymore force, and I will rip the dash out! It can't be this hard? How about it scott! Any thoughts?
I believe I would rather take the motor apart than try and get this @!$$& cup holder out!
Old 04-29-2013, 05:22 PM   #8
There is a piece of spring steel on the back side that gives it its detent. I find that it is easier to remove them if you first remove the screw and that spring. The problem is that you can only get to the screw if you lift the dash top, which means basically removing the whole thing.
Old 04-29-2013, 05:57 PM   #9
Melloreel
Drives: 08 3dr LB
Thanks scott! That's what I wanted, didn't want to hear. So Q tips will have to do for now!
Old 04-29-2013, 07:25 PM   #10
Kar98
Drives: 2011 Scion tC
Maybe a few bottles of canned air?
Old 04-30-2013, 12:46 PM   #11
Windex, a used toothbrush and a vacuum. Please don't use your current toothbrush.
Old 04-30-2013, 05:02 PM   #12
Melloreel
Drives: 08 3dr LB
I don't brush my teeth so will have to borrow one anyone open to lending me theirs
Thanks for tips though.
Old 05-02-2013, 12:06 AM   #13
nookandcrannycar
CUP HOLDER REMOVAL? SweetRS Cosmetic Modifications (Exterior/Interior) 13 09-19-2016 08:43 AM
Loose Change holder(?) and cup holder nemobile Cosmetic Modifications (Exterior/Interior) 14 02-21-2012 09:56 PM
Dash Cup Holder dzcab Cosmetic Modifications (Exterior/Interior) 5 08-17-2011 10:24 PM
cup holder removal DOMAV General Yaris / Vitz Discussion 9 08-27-2009 11:32 AM
