Old 04-15-2013, 02:59 PM   #1
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
what is best way to remove lower ball joints ?
I am having hard time removing the lower ball joint. thank you...
yaris4062007 is offline   Reply With Quote
Old 04-15-2013, 03:03 PM   #2
The tapered fork tools work well for stuck ones.
Autozone even lets you "borrow" those kind of tools. You have to let them ding your credit card, but they refund you when you return them.
Old 04-15-2013, 03:07 PM   #3
yaris4062007
thank you, is it safe not to damage ball joint, i tried hammering it and using the long extension bar failed :( . my other side was pretty easy but driverside giving me hard time haha .
Old 04-15-2013, 03:12 PM   #4
I had to use one on my Celica (which I don't think had been disassembled since it was built in 92) and it came apart without a problem and without damaging the rubber grease boot. For crazy stuck ones there is another tool that presses down on the bolt, but there are different sizes of those, whereas the fork tool is pretty universal.
Old 04-15-2013, 03:23 PM   #5
yaris4062007
Thank you, I will rent one from auto zone!! :)when removing the ball joint should i remove the two camber bolt then try to remove ball joint.
Old 04-15-2013, 03:47 PM   #6
I would at least loosen them to take some of the load off of the ball joint.
Old 04-15-2013, 04:23 PM   #7
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
I usually stay away from the forks as they rip your boots if you don't do it right. But if you have no other choice, then it will work for you.
I prefer these kinds:
http://www.harborfreight.com/3-4-qua...tor-99849.html
B2FiNiTY is offline   Reply With Quote
Old 04-17-2013, 02:27 AM   #8
yaris4062007
my ball joint boot ripped little bit after using forks and still didnt even work.. I had to use harborfreight tool get it removed, how long will it last without changing the ball joint??
Old 04-17-2013, 10:38 AM   #9
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Leave the nut on loose.
Smack the area of the knuckle that is around the ball joint stud, with a hammer.
Should be fine with one hit.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 04-17-2013, 10:41 AM   #10
Absolutely Red 12
Asshole
Not long!!
An aftermarket arm with joints go for $60 a side, best to replace.
Old 04-17-2013, 11:52 AM   #11
yaris4062007
How hard is it to install new control arm? Or should i just replace the ball joint only!! Where can i buy control arm for $60? Thanx
Old 04-17-2013, 04:19 PM   #12
You can go either route. The lower ball joints are about $11.
Old 04-17-2013, 04:41 PM   #13
esse10
Drives: 2009 yaris 2 door
control arms
Control arms replacement are not that difficult I've done them before in other front wheel drive vehicles except not the yaris, yet. It's mostly two or three big bolts to disconnect from subframe & disconnect the ball joint from the steering knuckle and your done. Just remember to replace those bolts cause they are usually one time use stretchable type. Torque the new bolts with the control arm parrallel to the ground as if the car was in it's normal driving state. Good luck man
Old 04-17-2013, 06:02 PM   #14
yaris4062007
I just ordered ball joint today for $32.00 plus rented ball joint presser $100 deposit from autozone. Do I need to remove control arm from the car ?? Thank you everyone!!! :) learning new stuff haha :)
Old 04-17-2013, 07:29 PM   #15
No. You can press it out (and the new one in) with the control arm still mounted.
Old 04-19-2013, 05:08 AM   #16
yaris4062007
Do i need to remove c-clip and rubber first to remove stock ball joint?
Old 04-19-2013, 07:18 AM   #17
Just the C-clip, then you press it out.
Old 04-19-2013, 12:02 PM   #18
yaris4062007
Thank you ct :)
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
MI SSK In-Cabin DIY (Golddeenoh) BEEF DIY / Maintenance / Service 5 03-26-2013 01:19 PM
