Old 04-16-2013, 02:12 AM   #1
wikkid_witch
Drives: n/a
Best offset that won't rubb
I have some 16x6.5 mini type s 7 spoke rims but I want way wider.
What is the best rim size to get a little poke. I am willing to fender flare.
I really like these but what staggered offset should I get?
http://www.ebay.com/itm/16-16x8-XXR-...item53f6b566be
Please help. I really like the orange slammed yaris with plaid hood and I think he is running 16x8 steels. But I like where his tire ends
http://www.google.com/search?q=slamm...UnVYUJxoyvM%3A
ohhi
wikkid_witch is offline   Reply With Quote
Old 04-16-2013, 06:39 PM   #2
wikkid_witch
Drives: n/a
bump help. making a decision soon
ohhi
Old 04-16-2013, 07:20 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
that is one cool orange yaris...love that look ...wow
Old 04-17-2013, 02:44 PM   #4
wikkid_witch
Drives: n/a
Yes it is very well put together. has me thinking of hand painting or vinyl my hood also.
ohhi
Old 04-21-2013, 12:11 AM   #5
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I have 15x8 with 25 offset on the back and it does not rub unless I am on a big bump....I am on DF210s and rolled fender...did not pull fender though...
16x8 with 0 offset would poke....you will have to run a stretched tire to make it not rub...and the 8" wheel in the front may poke more than looks good.
In the front on mine I have 15x7 with 35 offset and it is fairly flush...I put the rears on at it pokes witht he wider rin and 25 offset...but still looks a bit odd.
Old 04-22-2013, 11:39 AM   #6
wikkid_witch
Drives: n/a
Pics please? I am interested to see if 15s would be better than 16s. also do you ever have problems with the front rubbing with the 7"s
ohhi
Old 04-22-2013, 07:06 PM   #7
wikkid_witch
Drives: n/a
http://fabulouscars.be/?p=684
If the wheel and tire measurements on here are correct im going to try to get as close to this as I can
ohhi
slammed offset staggered
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 10:09 AM
Please confirm this fit (185/60R 15 on 15x6.5 +38mm offset) Dave55 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 03-03-2012 06:36 PM
Questioning the Recommended Tyre Widths based on Offset Energiser Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-24-2012 10:32 AM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
