Old 04-19-2013, 01:18 PM   #1
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
Kido 6pot BBK and 15" wheel selecetion?!
Just wanted to find out who maybe running the same Kido mini 6pot BBK?
I'm trying to see which wheels in 15" will clear these brakes using either 1 or 2 piece rotors as i'm currently using 1 piece setup:
15" wheels:
Volk TE37 15 x 7 offset +42 (fits)
Enkei RPF1 15 x 7 offset +42 (does not fit, barrel design)
Enkei PF01 15 x 7 offset +38 (fits better then the RPF but will require a small space + will have to shave down a bit of the caliper to work)
SSR Type C 15 x 7 offset + 43 (fits)
Konig Feather 15 x 6.5 offset +38 (fits)
16" wheels?
i'm curious to find out if ANYONE may have tried SSR Type F in 15 x 7 +42 offset?
DKN-YARIS is offline   Reply With Quote
Old 04-19-2013, 03:02 PM   #2
Type C's are no longer made, do you have some?
I have 16" Type F's, they clear those. Type F's are also discontinued.
Old 04-19-2013, 03:56 PM   #3
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
I have a friend with a set of Type C's so I tried those already.
I'm trying to find 15" wheels which is quite tricky as it seems as I already have a set of track tires so I need to find the right rim. 16" would be perfect if I didn't already have the tires here...
Old 04-19-2013, 04:00 PM   #4
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
Trying to see if anyone or if I can find a set of Work Emotion CR wheels will work with these Kido BBK.
Old 04-19-2013, 05:41 PM   #5
seth_man
seth_man's Avatar
Drives: 08 Liftback
6ul's will fit with a small spacer to clear the caliper
seth_man is offline   Reply With Quote
Old 04-25-2013, 11:27 AM   #6
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
Konig Feather (12lb) wheels in 15 x 6.5, ET38 fit perfectly with no spacers required.
Old 04-25-2013, 10:32 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
The Feather and Helium are good lightweight less expensive options. They were very popular wheels for Yaris autocrossers.
Colin Chapman disciple
WTB: Stock Steel 15" Wheel & Tire Cen Tex Chuck Southwest 2 12-16-2011 11:10 AM
WTB: one stock 15" steel wheel Camberix Willing to Buy by private party 2 10-15-2011 03:34 PM
WTB 1 15" Stock Steel Wheel b_hickman11 Willing to Buy by private party 0 06-23-2010 10:23 PM
WTB: 15" wheel cover for 07 hatchback kudzu71 Willing to Buy by private party 2 09-21-2009 10:37 AM
Looking for factory 15" alloy wheel stevencyt Willing to Buy by private party 1 10-23-2008 03:53 AM
