#1 |
The Flying Tomato
Drives: 2009 Red Yaris Hatchback Join Date: Dec 2009
Hey Ya'll
So I have been baffled with this for quite some time. I have a 2009 base hatchback. I do not have keyless entry (whether it is installed or not is beyond me). When I first bought my Yaris, I would always have to manually lock/unlock my locks - not surprising for a base model haha. One day I started my car just like I would normally, and the driver and passenger doors automatically locked when I shifted out of park (wtf?!?!). I know there are sequences of events that can program locking/unlocking with a key fob, but I don't have one. I thought that maybe I accidentally programmed the car to do this. I played around with different sequences and somehow undid the feature. After that, my doors wouldn't automatically lock for a while. Two days ago, I ran into a similar occurrence. When I started the car, my driver's door locked (not passengers); I did not shift the Yaris out of park. Now I know the first occurrence wasn't a fluke and that there has to be a way to program lock/unlocking without a key fob. Anybody know how? Otherwise I think my car is possessed!
The Flying Tomato
I also do not have buttons in the car that can automatically lock the doors.
#3 |
Only Happy When it Rains
Do you have power locks? Or power windows? I'd think more crossed/stripped wires than anything good.
Colin Chapman disciple |
#4 |
The 09 Yaris did not have that as a feature of the OEM power locks / keyless entry, so I would bet that your Yaris has an aftermarket keyless entry system installed. Take a look under the dash, below the steering column, for the aftermarket module.
#5 | |
The Flying Tomato
It appears to me that the problem is controlled rather than intermittent, I just don't know how it was induced/started. If it was due to shorted/stripped wires, wouldn't I see it more as an intermittent issue in the beginning rather than it happening consistently all the time like I'm seeing right now? Thanks! I would be surprised if an aftermarket keyless entry system was installed. I bought the car new from the dealer with ~20 miles on it. When I installed foglights a few months back, I didn't come across any wires or assemblies that seemed out of place or any that appeared to be aftermarket. Do you know off-hand if the newer/older models have that as feature? If so, which ones? Thanks! |
#6 | |
I don't believe that any of the Yaris do it. I know for sure that 06-11 do not. You can also pop one of the door panels off to see if aftermarket door lock actuators have been installed.
#7 | |
The Flying Tomato
![]() I know this is for a 2007 and not a 2009, but it says that the door lock feature that I am experiencing is a customization parameter for the 2007 year. I suppose it's possible they kept that feature for the 2009 model. I'm not sure what it's referring to in the first column "Display (Item)." Any thoughts? |
#8 |
The Flying Tomato
Actually, I'm re-reading the pdf, and it's talking about doors locking/unlocking through the door key cylinder and not through interfacing with starting the motor. I guess I'm still stuck haha
#9 |
Exactly. I still think you have some aftermarket stuff in there. Dealers sometimes add keyless entry locally to try to increase the value or marketability of a car. Sometimes if the buyer doesn't want it they just don't give them the key fob, rather than removing the whole thing.
#10 | |
The Flying Tomato
#11 | |
#12 | |
![]() Drives: 2000 Land Cruiser & 2007 Yaris Join Date: Nov 2012
I have a 2007 Yaris with power windows and key less entry... I was wondering how can i activate this mode to unlock only the driver door with one push off the unlock button and the others with two pushes |
#13 |
I am not aware of a way of doing it, other than by using the Toyota service tool.
#14 |
#15 |
Correct.
#16 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
I just wish mine would honk the horn when I hit the lock button on my remote.
#17 | |
![]() Drives: 2007 Yaris Join Date: Sep 2011
I have had a dozen cars with remote entry, and this is the only one that does not give you a horn chirp when locking. I'm getting old and I'm too lazy to look back at the car to see if the if the lights blinked to confirm the "lock". |
#18 | |
| Tags |
| automatic lock sequence |
| Power windows and locks on a 2009 3dr. | chilly79 | DIY / Maintenance / Service | 8 | 12-15-2010 12:55 PM |
| Should I buy an automatic? | ktoyo | New YARIS Purchase Forum | 40 | 06-23-2010 02:09 PM |
| Adding Automatic Locks | MrJester | DIY / Maintenance / Service | 15 | 06-08-2007 01:02 AM |
