Old 04-23-2013, 01:06 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Rods and Piston Question
I have cp piston and wanted to know.. what side does those little eye brows on top should be facing. The exhaust side or intake side. The same question for the Bearing Tangs.
Help
Old 04-23-2013, 02:17 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
isn't the intake valve larger than the exhaust meaning that it stands the highest chance of kissing the pistons, so I would assume that they should be on the intake side unless for some reason toyota makes their exhaust valves receive more open than the intake, but normally speaking it would be the intake side.
Old 04-23-2013, 03:16 PM   #3
Yoda
Yoda's Avatar
Yea i am not too sure I might have to pull out the manual...If I can remember where I put the darn thing.
Old 04-23-2013, 04:01 PM   #4
Yoda
Yoda's Avatar
Ok so for the Pistons they face on the Intake side. No info on the Bearing Tangs tho.
Old 04-23-2013, 04:22 PM   #5
Golddeenoh
Golddeenoh's Avatar
should be a dot, arrow, or something designating the direction to aim the piston to the front of the engine.
Old 04-23-2013, 05:15 PM   #6
kou
Drives: 08 lb
Looks like the exhaust side in the Toyota manual.
Old 04-23-2013, 05:29 PM   #7
Yoda
Yoda's Avatar
Thx it is the exhaust side for the Tangs. Time to slap this thing together.
Old 04-23-2013, 11:54 PM   #8
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
Bearing Tangs face to the exhaust side
piston to valve relieves face to the intake side
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Forged Pistons, connecting rods, piston rings etcetc mastaofdisasta Performance Modifications 2 04-18-2010 12:05 PM
Cp Pistons, Pauter rods , greddy, fidanza and other for 1NZ-FE!!! Giupo Items for Sale by private party 11 08-25-2009 02:57 PM
