Old 05-04-2013, 02:00 AM   #1
Steph85be
YTS ***** member
Drives: 2003 Toyota Yaris TS
FS: Cylinder head/Camshafts 1NZ/2NZ-FE
Hello all,
I'm selling a machined and polished cylinder head with regrindered camshafts for 1NZ and 2NZ-FE engines.
Here are the spec :
-regrindered camshaft (254° / 9.5mm Intake and 250° / 9.3mm Exhaust) the Toyota OEM is 8.8mm of lifter and IN 225° EX 224° of durations.
-3 angle valve seat
-heavy duty valve spring are MWR , this is the spec
1.300 -55 lbs (Stock are 37.1 lbs)
.900” 105 lbs (Stock are 71lbs)
Coil bind -.795”
tested up to 7200 RPM
You'll need your own camshafts brackets.
The price is 600$ + shipping cost
Steph85be is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Cylinder head bolt removal (Sequence) pozzydrive DIY / Maintenance / Service 1 10-19-2010 09:00 AM
DIY Hood Cylinder churp Cosmetic Modifications (Exterior/Interior) 46 06-25-2007 05:46 AM
Canada Only - Maybe a $1000 enviro rebate on Yaris> MDF New YARIS Purchase Forum 45 05-01-2007 08:17 PM
