Old 05-05-2013, 01:56 AM   #1
mamun22s
Drives: Toyota Vitz
Battery Losing Its Charge over night
I have Vitz 2000 /1300CC. When I start my car at morning it takes too long to start, needs 4~10 key stroke. But after start round the day it works good. Now Its very difficult to start. Now i goes to battery shop its only 6 months old and shopkeeper check and told me that the battery is good enough and suggest me to open the negative cable disconnect from the ground at night. And in my case its working. Now please any one help to how I find where it drain and what to check.
mamun22s is offline   Reply With Quote
Old 05-05-2013, 02:11 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
Do you have or have acesss to a test light or multi meter. Easiest way to locate the short is disconect the negative battery and introduce your multi meter across the terminal and measure the amperage draw, You probably have something like like half a amp if its killing the battery every night, or if not use your test light and see it it lights up brightly. Then start disconnecting fuses from your fuse box one by one till you see either the light go out or a drop in amperage.
That will isolate the circuit that has the short, if its something non essential such as the cigarette lighter you can leave the fuse out for the time being.
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Battery: charge or buy new? ziggyboy DIY / Maintenance / Service 9 10-17-2011 12:31 AM
2012 Ford Focus ELECTRIC Kal-El Off-topic / Other Cars / Everything else Discussions 11 02-11-2011 11:34 AM
