Old 05-09-2013, 11:12 AM   #1
sparkin88
Drives: 2010 Yaris 3D LB 5SD
Can't figure out.. if these wheels would fit.
Someone in my local car club is selling some enkei's
Offset: 42mm
Backspacing: 5.59"
Bolt Pattern: 4-100
Curious if they would fit, tried looking at the guide but couldn't figure it out.
All that I have done to the car suspension is MI lowering springs and cut a notch off the bump stops. Too wide?
sparkin88 is offline   Reply With Quote
Old 05-09-2013, 11:26 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
At this point, the tires themselves would be the biggest issue. I just got a set of 15x7 ET45 wheels with 205/50R15 tires and they look like they should rub, but somehow don't. Keep in mind that OEM tires are about 24" in diameter, so you're looking at some pretty thin rubber if you don't want to roll your fenders.
I'm also running Tokico blues with OEM bump stops and Tien s-techs, which is about the lowest drop you can do without coilovers. I'm sure someone here runs wheels that size, you just need to find them. Try playing with the search?
Old 05-09-2013, 11:57 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
17 x 7, ET42 is an excellent fit for the Yaris. Try 205/40 or 205/45 tyres depending on your drop.
Old 05-09-2013, 01:53 PM   #4
That's a great wheel fitment. +1 on the other comments.
Old 05-09-2013, 03:09 PM   #5
The Enkei's I had were those exact specs, and I used 205/40/17 tires.
Lowered on Tein S.Tech springs, I experienced no problems with them. However, on full steering wheel lock to the left, I think it very slightly rubbed on the inner fender. No biggie tho.
Old 05-09-2013, 11:13 PM   #6
sparkin88
Thanks for all the feedback! I might jump on the deal. Nice setup for a little show, eventually will have koseis or rpf1s in 15 for my auto cross endeavors and have car setup in STF a little better.
Photoshop Guru Needed: Paste Honda fit sport wheels on my 2011 Yaris henrylee Photo-Video-Media Gallery 0 03-05-2012 07:33 PM
would these wheels fit correctly? pspeezy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2011 03:35 AM
Test drove Rio5, Fit, and Yaris all today kmf123kmf New YARIS Purchase Forum 16 10-02-2009 07:48 PM
Will 13" Civic wheels fit? evan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-15-2008 10:36 PM
