Old 05-14-2013, 09:20 PM   #1
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Is my water pump going out?
I have noticed my fan belt making a squealing noise at start up. My 09 Yaris has about 87K miles and never had any maintenance problems so this has me concerned.
My guy feeling is to have the water pump replaced along with the belt. Has anyone else had a similar problem?
Big Dave
Indianapolis, IN
Old 05-14-2013, 09:33 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
water pump would cause more issues, more likely belt stretch, adjust tension before by moving the alternator first, also make sure that there aren't and alignment issues with the pulleys and that the pulleys are clean of debris and that the belt does not have cracks or chips in it.
Old 05-14-2013, 09:35 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
just tighten the belt...a 12 mm and a 14 mm bolt , slide the alternator forward..just dont go to tight with the belt also look for cracks if it needs replacement just do it.
Old 05-14-2013, 09:35 PM   #4
esse10
Drives: 2009 yaris 2 door
belt noise
If you bought this car new and never changed the belt once than most likely that's your problem. It's gotten old and needs to be replaced before it breaks on you man. Most belts only last about 3-4 years. I change mine every 4 years even if their not squeeling or still look good, why take the chance of getting stranded. Water pumps usually start leaking from the weep hole when their about to go bad, if you see coolant on your garage floor and trace it back to the pump, it's time to replace it ASAP before it leaves you stranded and damage the engine in the process.
Old 05-14-2013, 09:37 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
I needed to replace my belt at 87k miles. If it's original just replace it and see how it goes.
Old 05-14-2013, 11:00 PM   #6
daf62757
daf62757's Avatar
Good input guys! I will replace the belt and let you all know how it turns out.
Big Dave
Indianapolis, IN
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
water pump change 2sz-fe finnpoulsen DIY / Maintenance / Service 5 03-25-2020 10:20 AM
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
