Old 05-15-2013, 01:18 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Choosing wire - volt/amp
I am connecting some LEDs for decoration in the car, the LEDs are rated are 1W each, I will be connecting that to the cigarette lighter wire. I am wondering would a 26AWG gauge wire be enough connection between 12V and the LEDs?
Thanks
caineroad is offline   Reply With Quote
Old 05-15-2013, 06:11 AM   #2
26 AWG stranded wire is rated for about 2.2A, so you could theoretically power 25 1W LEDs off of it (as each draws .08A).
Old 05-15-2013, 09:31 AM   #3
caineroad
caineroad's Avatar
Yes, I am wondering though if I do with 26AWG which is ok, but what happens if I plug in a power inverter or something that draws a lot of energy in the cigarette lighter which will brings a lot of current, is it going to have problems or burn out my 26AWG that is attached to the cigarette lighter wire?
thanks
Old 05-15-2013, 09:52 AM   #4
thanks
It won't have any effect. The devices connected to a piece of wire will only draw more current if the voltage sags when another device is plugged in to the system.
So, for your LEDs, my 25 above was based on a system voltage of 12V, as opposed to 14V when the alternator is spinning. When the engine is running you will draw less current than when it is off (higher voltage = lower current).
I would recommend though installing a 2A or 4A max fuse inline with your LED wiring. The fuse for the lighter is 15A, so if you accidentally shorted your LED wiring the 26AWG wire would burn up, without popping the 15A fuse, so to be safe when you branch off a circuit with smaller wire you should always add a fuse appropriately sized for the branch wire.
Old 05-15-2013, 10:35 AM   #5
caineroad
caineroad's Avatar
Wow, very informative and knowledgeable, thank you very much again! Will follow your advice to adding a fuse.
Old 05-15-2013, 11:11 AM   #6
BLH
Drives: 2007 Yaris Sedan
Just don't connect the inverter to the 26 gage wire. In that case it is too thin for the needed current.
Old 05-15-2013, 01:28 PM   #7
If you hook up lighting to the cigarette lighter circuit, won't it only work with ignition on?
Old 05-15-2013, 01:34 PM   #8
Correct
Old 05-15-2013, 07:38 PM   #9
caineroad
caineroad's Avatar
Yes, that's right. I am installing interior mood lighting, similarly found in Mini cooper, not the lighting to use in event or shows.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Scion XD LED mirror install pics aplenty enviri DIY / Maintenance / Service 76 07-21-2019 02:10 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
