Old 05-17-2013, 12:53 AM   #1
TOLMACH
Drives: soarer
Noob turbo (zage) questions
Decided to start another thread as i have lots of really noob questions
Below is what I plan using for my oil return: 10AN fittings.
Question: Do i need any sort of paste or compound to assemble these things? There are not any sort of rubber spacers inside. It looks as if I just need to assemble them tight and aluminum against aluminum (convex vs concave surface) should provide a tight seal.
Opinions?
Thanks
Old 05-17-2013, 01:47 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Do not use tape or paste on AN fittings. The taper seals it.
Old 05-17-2013, 01:50 AM   #3
TOLMACH
Drives: soarer
thanks
Old 05-20-2013, 10:49 PM   #4
TOLMACH
Drives: soarer
What engine oil are you (turbo heads) using?
Can I keep using Pennzoil Platinum 5w30 (that I like a lot)?
Old 05-21-2013, 07:54 AM   #5
I'm pretty sure oils will indicate in writing on the back weather they're safe for turbos or not. Full synthetics usually work best.
Old 05-21-2013, 10:47 AM   #6
5w30 synth is good -- I don't run anything exotic. I change it a lot more often.
Old 05-21-2013, 12:21 PM   #7
TOLMACH
Drives: soarer
^ Thanks
Old 05-21-2013, 10:39 PM   #8
Focus_Sh1ft
Focus_Sh1ft's Avatar
I'd use permatex black or equivalent where the fitting connects to the inside/outside of the block. You won't be threading it into the block, as it's too thin to really grab any of the threads.
Old 05-21-2013, 11:51 PM   #9
TOLMACH
Drives: soarer
^ Thanks
This is p.black I belive. Will buy some for my install
http://www.amazon.com/Permatex-82180.../dp/B0002UEN1U
The scariest part right now seems to be drilling )) One does not come to drill a 18 mm hole in this engine every day ))
Old 05-22-2013, 12:29 AM   #10
18mm? that sounds a lot larger than necessary.
Old 05-22-2013, 01:23 AM   #11
TOLMACH
Drives: soarer
10AN - 18 mm oustide diameter - just measured it
http://www.ebay.com/itm/181134096470...84.m1497.l2649
plaan to use something like this stepped bt
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 10:42 AM
Zage turbo kit Mister Z Forced Induction Forum 17 11-26-2010 03:32 AM
noob here.. need help on questions about turbo and engine life 10Kyaris Forced Induction Forum 43 10-06-2010 09:26 AM
zage turbo kit..! just need some help joseyaris Forced Induction Forum 12 10-29-2009 08:35 PM
