Old 05-17-2013, 09:50 AM   #1
kou
Drives: 08 lb
Another wheel size fitment thread
I am thinking of getting some 15x7 et30 with some 195/50/15 rubber I am lowered on TRD springs. I am wondering if anyone is running this setup or similar and if you have rubbing issues.And any pics of the poke. Thanks in advance.
Old 05-17-2013, 11:15 AM   #2
Not much of a wheel poke, and no tire poke at 195, I think.
Is that a smaller profile than stock? You should be totally fine with that.
Running any camber?
Old 05-17-2013, 11:19 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
This guys is running 15x7 +20 almost same as you want but he is way lower, dropped on bc coils so you get an idea of what it looks like. It prolly wont poke at all and you should have no rubbing issues with that small of a drop.
Old 05-17-2013, 02:13 PM   #4
kou
Drives: 08 lb
Thanks guys maybe I will go et25 then, either way I will pull the trigger next week. And yes to camber when i switch out my control arm bushings I will throw some camber bolts in.
Old 05-17-2013, 03:05 PM   #5
1.5
Form>Function
1.5's Avatar
Are you cool with rolling fenders? If you are and you run negative camber, you can run some pretty agressive sizes. Are you choosing these wheels because they are the style you wana run or are you running them because of the fitment they will give you?
Old 05-17-2013, 03:38 PM   #6
kou
Drives: 08 lb
They are the same wheels I have now just different offset TRmotorsport (wholesale price $74 each)cheap,light and my friend has a set never used BFG sport comp2 that he is giving me for $100 so just wondering what will fit with the least headache.
Old 05-17-2013, 05:26 PM   #7
1.5
Form>Function
1.5's Avatar
gotchya ok. Yeah you really shouldnt have a problem and you can run a slightly wider wheel/lower offset if you want.
Wheel Size Preference RANDUMB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 04-21-2010 02:27 AM
Help on YR Wheel Size hazzy Australia 11 04-06-2010 08:09 AM
Wheel size & weight, and how they affect overall performance? Share your thoughts Schizoprenia Performance Modifications 8 02-02-2010 09:09 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
non yaris aggressive wheel thread @po_crew Off-topic / Other Cars / Everything else Discussions 11 05-08-2009 11:19 AM
