Old 05-19-2013, 09:53 PM   #1
fatlard
Drives: 2010 Yaris Auto Sedan
Factory Tires... How long did they last for you?
I am at 46k.
How much longer do I have?
fatlard is offline   Reply With Quote
Old 05-19-2013, 10:15 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Mine lasted about 15k on my third set of tires at 53k but I drive a bit more aggressively than the average driver
Old 05-20-2013, 01:22 AM   #3
swidd
Drives: Yaris HB
Long time ago, I think around 40-42k, but very thin after 38k.
Old 05-20-2013, 05:19 AM   #4
Yaristeve
Drives: 3-door hatch
A lot will depend on your driving. I use my Yaris for my commute of 35miles one way, about 70% on mostly uncongested freeways. My first set of tires lasted 60k miles without rotating at all. I probably could have gotten another 5k if I had rotated my tires a few times...
Old 05-20-2013, 07:16 AM   #5
nookandcrannycar
My Factory/OEM set of 4 lasted 71,480 miles.
Old 05-20-2013, 01:22 PM   #6
sex
sex's Avatar
Drives: 09 5DR
OEM Goodyears are at 6/32nds after 60k. Rotations every 5k and 37psi all around. 60/40 hwy/city driving
Old 05-20-2013, 01:39 PM   #7
RABYARIS
RABYARIS's Avatar
Drives: 2009 Yaris 3D AT
30K miles, 5/32nds left on tread...
'09 AT, CC, PW, PDL, Key Less Entry, A/C, MP3, Trailer Hitch, Hard Wired Garage Door Opener
RABYARIS is offline   Reply With Quote
Old 05-20-2013, 06:41 PM   #8
Foot
Drives: 2010 3dr yaris
15k I should had replaced them, but I drove another 5k.
Foot is offline   Reply With Quote
Old 05-21-2013, 11:58 AM   #9
NEexpat
Drives: 2009, auto, 4dr LB
At 43k now, will run these till winter put on snows and that will be it. Get new ones next spring.
So i'm guessing 48k-50k.
NEexpat is offline   Reply With Quote
Old 05-21-2013, 12:54 PM   #10
justjesus
justjesus's Avatar
Drives: 2008 Liftback
2008 yaris - I'm at 75k miles.
Two still look new (people keep asking if I bought them recently) the other two are still looking good at about 80-85%
Old 05-21-2013, 01:20 PM   #11
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
has to replace the front 2 at 20k and then when the rears were roates to the front they got replaced at 25k. then i got new rims and tires at 45k so yea, not getting longevity out of them.
i tend to take corners with out braking so it tends to ware the tires down a bit, plus my old neighbor hood when i was in service had a 180 degree turn to get into it that i tended to whip around and when i started to slide on the dry pavement i would know it was time for tires, lol
Old 05-21-2013, 02:58 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Mine werent the goodyear tires I don't think. They were the other ones they offered in the 07 model year. I got 38k on mine before having to change out because they were just horrid and really got bad at hydroplaning at highway speeds. They were junk.
Old 05-21-2013, 03:15 PM   #13
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
Bridgestone Turanza EL400 tires on mine.
Never heard of them but I'm going to trade them into Discount Tire for a little bit off a new set.
I don't like Bridgestone anyways to be super honest.
The car could definitely ride better too. I'm only on 256 miles on these.
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 05-21-2013, 07:02 PM   #14
mr_miles
Drives: 2013 Yaris
two of my OEM ones are at probably 60% due to putting them on the white yaris while its new owner learned how to drive manual.....lol. the other two barely look like they've been used. all together I think those 4 tires have 12k on them.
Old 05-23-2013, 01:38 AM   #15
Aamya
Drives: audi
Hey everyone,,.
Does anyone know what factory tires came on a 1999 Lexus ES300 ?
Waiting for your idea,.?
Aamya is offline   Reply With Quote
Old 05-24-2013, 02:11 PM   #16
Steve L.
Steve L.'s Avatar
Drives: 2010 Toyota Yaris 3 door
I went to Discount Tire today and they told me I need to replace them now. And, I have 45,000 miles on my factory tires. They wouldn't even rotate because the tires had cracks on the side of them. I can get Michelin Defender tires with a 90,000 miles warranty for $573.50 out the door. That is what I am going to buy. The ones on the car now are Good Year Eagle LS tires and they only have a 40,000 miles warranty and they cost a total of $50 more dollars out the door. That doesn't make no sense so I will get the Michelin Defender tires because they will last twice as long and they are cheaper then the ones on there. That makes more sense right!!!
Steve L. is offline   Reply With Quote
Old 05-25-2013, 01:21 AM   #17
JohnnyRockets
Drives: 2007 Yaris Sedan
47,000 miles.
3 of the 4 were fine but the front right tire kept deflating to from 32 to 18 every single time I went to get gas. After this happening 4 times, I decided to just replace them all.
They lasted 6 years so it's better to replace now than to deal with a flat, stranded on the side of the road, and have to pay a tow truck.
The cost savings of continuing to drive on 50k+ tires doesn't offset the cost of the tow truck -- am I right?
JohnnyRockets is offline   Reply With Quote
Old 05-25-2013, 03:32 AM   #18
nookandcrannycar
Originally Posted by JohnnyRockets View Post
47,000 miles.
Depends on if you have AAA or not and, if so, how many times you had to call them in a year.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Best All Season tires for Yaris HB. edmscan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 05-27-2012 11:49 PM
General G-MAX AS-03 Tires scape Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 11-28-2011 07:29 PM
Ebay find factory 17 inch wheels and tires for 529 YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-05-2010 05:12 PM
