#1 |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
Aftermarket steering wheel audio control??
Has anyone found anything that works with our car, got a new headunit, looking to get some audio controls mounted on steering wheel for better access, thanks
Steve (Echo_hrs) bought a JDM Yaris steering wheel with the audio controls and connected it to his aftermarket radio using one of the PAC steering wheel control modules. If you don't have cruise control installed you have two extra wires in the clockspring that can be used. If you have cruise, a JDM or 3rd generation Yaris clockspring has the extra wires required to run both cruise and audio controls.
#3 |
Is there anything out there that is just an aftermarket clip on thing?
3rd gen yaris, you mean 2012+? Wasn't there is a thread somewhere that people tried to fit 2012 wheels into our yaris but no success? |
#4 | |
I am not sure about the 2012+ steering wheel fit on a 2nd gen Yaris, but I am almost positive that the clockspring would work.
#5 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Aftermarket HUs have remotes for steering wheels
Below is an example for pioneer hus http://www.ebay.com/itm/Steering-Whe...39c0e5&vxp=mtr |
#6 |
#7 | |
#8 |
This is where I bought it and the information given
http://www.autodvdgps.com/car-dvd-gp...ies-p-565.html |
#9 |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
hi scott, i know this is an old thread. but after thorough searching online and in yw, I've come to conclude that if the clockspring connector below the column (white 10-pin/12-pin, the one beside the yellow one for the airbag) only has an X number of wires, then there are also X number of connections you can make with the connector to the steering wheel itself.
Example, if i have only 3 wires there, and since one of them is for the horn, i can only use the other 2 for steering wheel audio controls, bluetooth or cruise control. Is this accurate? I mean, can we not "pin" the white connector below the column and also pin the connector on the steering wheel? in other words, does the clockspring ribbon have wires inside for this? |
#10 | |
#11 |
#12 |
here's the connector on the JDM audio control for reference.
#13 |
![]() Drives: 2013 Toyota Yaris Hybrid Join Date: Jun 2014
Keep in mind that the cruise control also goes through the clockspring. I keep planning to tap into that clock spring connector to design a clever way to use the cruise control arm as steering wheel controls when the cruise control is not in use but just haven't had the time.
#14 | |
| Steering Wheel question | heeroyuy01195 | Cosmetic Modifications (Exterior/Interior) | 33 | 03-07-2012 01:27 AM |
| Steering Wheel Controls - Part 2! | revolution | Cosmetic Modifications (Exterior/Interior) | 3 | 11-26-2010 02:53 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| audio volume control on steering wheel | hans_fh | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 01-04-2009 09:07 PM |
