Old 05-21-2013, 10:42 PM   #1
Echo56
Drives: 2003 toyota Echo
Flywheel question-1nz conversion-2003 Model
Gidday Guys
I have 2003 Toyota Yaris/Echo Hatch.
I have just pulled out the 2nZ 1.3 motor, and about to lower in the
1nz 1.5 motor.
The problem I have is the 1.5 1nz was an automatic, so I have just pulled off the torque convertor and flex plate, I have sat the flywheel on.
The flywheel fits from 2nz to 1nz which is good, but I have no way of aligning the flywheel.
Most people say just mark the flywheel as you remove it, but this engine never had a flywheel.
As some people know the back of the flywheel has 5 holes (that don;t go all the way through) In line with the middle hole is a white spot, this appears to be the thing to use to put it on correctly??
Question 1: Does it matter
Question 2: What do I align it with.
Any help would be great. Thanks
Aftermarket repair books don't seem to mention it.
Echo56 is offline   Reply With Quote
[WTS] Brand New Sport Rims 1151127 Items for Sale by private party 20 03-21-2013 11:28 PM
Most Reliable Makes of 2010 2007yariz General Yaris / Vitz Discussion 16 12-02-2010 03:37 PM
HB base model back seat, question Hotwheel General Yaris / Vitz Discussion 25 11-16-2009 02:40 AM
flywheel question White Yaris DIY / Maintenance / Service 4 03-16-2009 09:34 PM
Power lock conversion question mybabygirl DIY / Maintenance / Service 9 04-08-2007 07:47 PM
