Old 06-05-2013, 01:58 PM   #1
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
Biggest spacers?
What's the biggest spacers you can throw on the yaris with only adding spacers? If you wanted more than just a few mm, what would be the route from there?
Club SHIFT
Old 06-05-2013, 02:04 PM   #2
That will depend on what you are running for tires and rims. With stock sized tires and rims, 10mm would be about the limit for the fronts.
Old 06-05-2013, 03:11 PM   #3
TickleTimeTim
Free Mustache Rides
So I take the backs have a little more play? Yeah, on stocks currently.
Club SHIFT
Old 06-05-2013, 03:39 PM   #4
Correct - The rear wheels are set in more than the fronts. Also, since the rears don't turn, that also helps.
Old 06-05-2013, 04:02 PM   #5
13mm hub spacer kit works well. You can use anything from 5mm-30mm, but you'd need a reason to do so.
Old 06-05-2013, 05:35 PM   #6
I also wouldn't use anything thicker than 5 or 7mm wheel spacers unless you install some extended lug studs, otherwise, you'll only catch 3-5 threads.
Old 06-05-2013, 06:10 PM   #7
TickleTimeTim
Free Mustache Rides
So it's worthless on stocks. I might as well wait for wider wheels then get spacers? Well I ordered my lip kit today and next is a good from Garm, wheels and spacers will have to wait til after that.
Club SHIFT
Old 06-05-2013, 06:11 PM   #8
TickleTimeTim
Free Mustache Rides
Hood* from Garm. Autocorrect hates the word hood
Club SHIFT
Old 06-06-2013, 10:18 PM   #9
TickleTimeTim
Free Mustache Rides
These bad boys are $100 but located 4 hours from where I live. They don't include tires. 4x100 14"
Club SHIFT
Old 06-06-2013, 11:19 PM   #10
What are the specs, such as width, offset, and center bore?
Old 06-06-2013, 11:38 PM   #11
TickleTimeTim
Free Mustache Rides
He just sold them. He didn't have it listed and sold before I could ask
Club SHIFT
Old 06-22-2013, 01:45 PM   #12
TickleTimeTim
Free Mustache Rides
Has anyone here ever done the 2" (50mm) spacers with the studs? I'm interested to see how much that would look like a go cart
Club SHIFT
Old 06-22-2013, 02:52 PM   #13
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
I had 30mm in the back.. but then I had 16x6j original toyota rims... the wheel just poked out. Also... it rubbed alot when i had people in the back, hahah... serious rubbing!!! still a cool sight though!
I now have 15x7 (ET25) and i want to do 15mm/20mm spacers in a few months...
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 06-22-2013, 03:09 PM   #14
TickleTimeTim
Free Mustache Rides
I was thinking at least an inch width if I was to do it with the stock 15" rims. Do you have any pictures of how it looked?
Club SHIFT
Old 06-23-2013, 08:28 AM   #15
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
1" currently. But I have a lot of fender work done
Old 06-23-2013, 10:48 AM   #16
TickleTimeTim
Free Mustache Rides
Notice any extra wear on your tires?
Club SHIFT
Old 07-01-2013, 11:57 AM   #17
d3310n
Drives: black titty
how big could i go with 17x205?
d3310n is offline   Reply With Quote
Old 07-01-2013, 12:21 PM   #18
1.5
Form>Function
1.5's Avatar
you mean on the contact patch or sidewall?
contact patch: yes because im running -~6 camber
sidewall: depends on the wheel/tire size
the spacer alone wont cause any wear
Hood Spacers. First Ever on YarisWorld! 1.5 Photo-Video-Media Gallery 58 12-04-2012 08:45 AM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
question on Rear Hub Spacers mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-02-2010 09:54 AM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
