Old 06-08-2013, 12:42 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
LED turn signals
Does anyone know if 7507a is the ONLY bulb that would work for the yaris 06-11 ?
I tried to find some good looking powerful 7507 led on ebay but so far nothing is good, can i use other 7443, 7440 or any other etc?
thanks
caineroad is offline   Reply With Quote
Old 06-09-2013, 08:47 PM   #2
caineroad
caineroad's Avatar
anybody?
Old 06-09-2013, 09:46 PM   #3
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
I use 1156 (P21W) bulbs on mine.
I had to file off one of the bayonet lugs so it could fit though.
No problems so far.
Mittelklasse is offline   Reply With Quote
Old 06-09-2013, 09:50 PM   #4
caineroad
caineroad's Avatar
does it matter which side you file off the lugs?
Old 06-09-2013, 10:11 PM   #5
caineroad
caineroad's Avatar
btw, what resistor did you use? same specs for front/back?
Old 06-10-2013, 12:15 AM   #6
Mittelklasse
Problem, officer?
It doesn't matter.
No, I don't install resistors. That would defeat the purpose of using LED bulbs (lower energy consumption).
But if the hyper-blinking does bother you, you should look for a turn signal flasher relay for LEDs.
Old 06-10-2013, 12:16 AM   #7
caineroad
caineroad's Avatar
oh i see but in truth i buy the LED for looks, not lower energy consumption, the amount of energy saved is negligible lol
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 11:39 AM
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 02:16 AM
Green 24 LED Turn Signals 7440 fnkngrv Cosmetic Modifications (Exterior/Interior) 15 08-01-2010 11:04 PM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
led turn signals.. marcus Cosmetic Modifications (Exterior/Interior) 6 03-16-2009 08:49 AM
