Old 06-10-2013, 01:32 PM   #1
talhahs
Drives: Toyota Yaris 2010 SD AT
Yaris breakdown : Engine starting issue
I left my office, reached parking area and my Yaris wont start. I parked it around 8:30 AM and tried turning it back ON at 5:30 PM.
On moving the key, dashboard didn't light up. I realized there is something wrong with battery..horn too didn't sound powerful. Hence, I got it working after connecting the booster cable with the other battery. Now the strange part is as soon as I leave my foot off the accelerator pedal, rpm goes down (either in N or D) and it stalls and finally goes OFF (in 2-3 seconds). I got it back ON with booster cable 6-7 times but every time leaving it foot-free gets it stalled and engine OFF. With foot ON, engine got warm and no sign of issue.
Battery connections are tight and no sign of salt/anything..
What could be the reason of this problem? Another thing I was observing from a while that in N position with no foot on pedal, it used to slightly get stalled i.e. flickering of ODO backlight as if engine wud go off, engine rpm going down (below 500), etc but never got OFF. Everytime I used to accelerate, it got fine, ODO backlight solid
Please share what cud be the reason of this issue...my Yaris still parked at office...
talhahs is offline   Reply With Quote
Old 06-10-2013, 02:13 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
alternator not charging your battery.
alternator dying, too?
Old 06-10-2013, 02:25 PM   #3
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Sounds like it's not charging. Check the fuses and fusible links.
I got a spare alternator off Ebay for $50. If you get a used Alt, make sure the last digit in the model # is a 1 and not a 0.
Good luck.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 06-11-2013, 01:00 AM   #4
nookandcrannycar
Good luck.
Are the ones with the zero as the last digit in the model number specific 07s that had faulty voltage regulators inside ?
Old 09-13-2013, 11:25 AM   #5
talhahs
Sorry, I know I am too late....But the problem was solved the other day.
It was the throttle body issue...I managed to take my car to the mechanic after installing a new battery....although the car went off 10-12 times on the way to workshop.
Well, he just cleaned the throttle body using ACDelco carburetor cleaning spray...and RPM was back on....as stable as it cud be in Yaris.....
