Old 06-13-2013, 07:06 PM   #1
dstephens1962
Drives: 08 yaris
A/C Compressor Install
Hello guys im looking for some info on the easiest way to swap A/C compressors. Any help or wright ups would be greatly appreciated. 2008 Yaris
dstephens1962 is offline   Reply With Quote
Old 06-13-2013, 07:17 PM   #2
Take a look at the "Air Conditioning" section of the service manual, which you can download on the Micro Image forum (http://www.microimageonline.com/foru...32-YARIS-FILES).
If the system is still charged, you will need to have it evacuated first to safely remove the Freon. Once that is done, you loosen the drive belt, disconnect the two hoses from the compressor, and then remove the four mounting bolts.
Reverse the process with the replacement one, and then have the system purged and refilled.
Old 06-13-2013, 08:06 PM   #3
dstephens1962
Drives: 08 yaris
ok thanks
Help: A/C Questions flamingchicken4 DIY / Maintenance / Service 11 12-29-2018 12:53 PM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
