Old 06-16-2013, 02:05 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Stiff steering wheel
Recently my steering wheel is noticeably harder to turn, I am suspecting is the power steering, but it is electric, so no need to change fluid.. I checked the tire pressure, both front tires are 37PSI, which is not under-inflated. What is the problem?
thanks
caineroad is offline   Reply With Quote
Old 06-16-2013, 03:46 AM   #2
Astroman
Modded Moderator
Astroman's Avatar
Did the power steering light turn on? I know it's electric but there is a light in the dash for it. CTscott might have some ideas, the steering is speed adaptive so it's possible it thinks you're at highway speeds at all times.
Old 06-16-2013, 06:07 PM   #3
Check to see if the EPS fuse is blown. If not, like astro said, does the PS light come on?
Old 06-17-2013, 03:15 AM   #4
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
This might sound weird, but on my Yaris the more tire pressure -- the harder to turn the steering wheel.
I think it has to do with how the EPS sensor reads inputs from the tires. Angular friction and stuff.
It might think 'Oh, his tires were so over-inflated it's so easy to turn. Guess I don't have to assist him much, eh?'
Mittelklasse is offline   Reply With Quote
Old 06-17-2013, 03:17 AM   #5
Mittelklasse
Problem, officer?
Oh, had an alignment job recently? You caster angles could be off, too.
Old 12-21-2013, 01:45 AM   #6
honestabe
The Battery Guru
Drives: 08 2-door hatchback 5-speed
I smacked into a curb this morning at a 40 degree angle. Now my steering wheel is stiffer and doesn't turn back as easy. I couldn't see any damage besides the curb rash on my rim. Is it possible I popped the EPS fuse or broke the EPS sensor?
honestabe is offline   Reply With Quote
Old 12-21-2013, 06:20 AM   #7
It is easy enough to check the fuse in the under-hood fuse panel. If the sensor was bad (which is part of the steering column) the PS light would stay on all the time.
Old 12-21-2013, 09:23 PM   #8
honestabe
The Battery Guru
Fuse isn't blown and the PS light isn't on. Maybe I damaged a servo or my alignment is off?
Old 12-21-2013, 10:10 PM   #9
Alignment being off is definitely an option. There is one big motor that provides the power assist. The zero point calibration of the torque sensors may be off as well. That calibration can be done with the Toyota Techstream tool.
Old 02-21-2015, 05:24 AM   #10
fbq262ken
Drives: Toyota Yaris (2004)
I have this problem too. I hit the curb, in fact I replaced my wishbone due to this, now the steering is harder (noticeable when I am trying to park).
My alignment was off and so I did an alignment exorcise, the problem is that when I need to turn a complete rotation, it is harder to turn upon reaching the very end of the rotation. What could be the problem?
fbq262ken is offline   Reply With Quote
Old 02-23-2015, 09:19 AM   #11
fbq262ken
Bump for someone who is perhaps viewing the post at this time of the day.
Old 02-23-2015, 05:59 PM   #12
Did you replace the wishbone with a genuine Toyota one or with an aftermarket one?
Old 02-23-2015, 11:29 PM   #13
It's possible the steering rack itself is damaged.
Old 02-26-2015, 09:15 AM   #14
fbq262ken
Nope with a Toyota one.
Old 02-26-2015, 09:17 AM   #15
fbq262ken
How much would that cost?
Old 02-26-2015, 12:22 PM   #16
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
was 1k€ for me.
I drive, therefore I am.
Old 02-26-2015, 01:45 PM   #17
First confirm the rack is bent then if it is get a used one from an auto wrecker.
Get the front wheels off the ground and turn the wheels back and forth.
Sent from my iPod Touch
Old 03-25-2015, 01:42 PM   #18
matchap801
Drives: Yaris D-4D
Hi, i had a similar issue, it turned out to be a very weak vehicle battery. Removed it and charged it for a few hours and has improved the steering no end. The car only does lots of short journeys these days so never gets a decent charge. Good luck. Matthew
matchap801 is offline   Reply With Quote
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
