Old 06-17-2013, 01:35 AM   #1
dizdiz
Drives: Toyota Yaris 2009 Sedan
Toyota Yaris Spedometer Accuracy?
Sorry I am new to this forum and I am short on time so I couldn't search and figured this was an easier way to find an answer. I was given a 2009 Yaris sedan with 13k miles (thank you grandpa) and I love driving it but the middle dashboard confuses me. How accurate is it if viewed from my driver side angle? Did they change anything to where the speed you see is accurate?
dizdiz is offline   Reply With Quote
Old 06-17-2013, 06:25 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
There is some parallax error when viewing it from an angle, but there are other things that will have a much greater impact on accuracy. Tire size is the number one thing that I can think of. There are several different OEM diameters, all in the 23-24" range, but the difference in speedometer vs actual is well within an acceptable margin at most speeds.
For example, my 205/50r15s show about 70 on the speedo but 67 on my GPS. From the passenger side it looks like 68-ish, so I wouldn't worry about it too much.
Old 06-17-2013, 11:28 AM   #3
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Check it against a gps. Driving on a straight level road the gps should be very accurate, as long as you are driving out in the open, not up against any hills. I'm sure they took the parallax error into account when they designed that center console.
Amdkt7 is offline   Reply With Quote
Spyder Auto 06-08 Toyota Yaris Sedan Headlight/TailLights FREE set in SoCal!!! rmota83 California 14 03-24-2013 04:41 PM
