Old 03-24-2007, 07:05 PM   #1
spkrman
Drives: 1
Threw some 20's on the yaris
MB spark, 225/30/20's
Pics later tonight
One note... time for some dezod pads!!!!! It feels like I'm stopping a 5000lb suv with bad brakes.
Old 03-24-2007, 07:38 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
bump 4 pics
Old 03-24-2007, 09:21 PM   #3
ChinoCharles
Drives: LB
Rims fit for the finest audio guru in the midwest.
Can't wait to see the pics.
Old 03-24-2007, 09:28 PM   #4
acrbill
Drives: Polar White Hatch
pics or ban.
Old 03-24-2007, 10:28 PM   #5
uncleyaris
echo said it best!
Old 03-25-2007, 05:37 AM   #6
spkrman
Drives: 1
cardomain just setup: http://www.cardomain.com/ride/2603562
the obligatory "before" pic
rubs full lock and big bumps.
This should be in the wheels forum lol...
Old 03-25-2007, 05:40 AM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Those are some very large wheels
SPONSORED BY
Old 03-25-2007, 05:50 AM   #8
spkrman
Drives: 1
although, they don't really look so "oversized" on the car... then again I'm used to this sort of look lol.
Lots of folks are gonna mistake (already happened tonight) for 18's, and I'm not sure if I can bring myself to put one of those 20" badges on the side....
Old 03-25-2007, 09:46 AM   #9
pc1x1
Drives: Yaris 2007 Liftback (Jan 07)
A Yaris blinging on 20's, I seen everything ;)
pc1x1 is offline   Reply With Quote
Old 03-25-2007, 11:12 AM   #10
grimez
grimez's Avatar
Drives: 2007 Yaris
Question: Can you turn?
grimez is offline   Reply With Quote
Old 03-25-2007, 01:09 PM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
So when ya going to lower it?
Old 03-25-2007, 01:10 PM   #12
ChinoCharles
Drives: LB
You need a Skyjacker and some 26's.
Old 03-25-2007, 02:02 PM   #13
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
when i first got my 17" rims I had massive tires on them because I got them for free...they had as much fender gap as his 20s do.
If you turn all the way one way or the other they rubbed, the fronts rubbed against the fenders if you hit a bump or pothole while driving, the rears rubbed against the plastic mudgaurd in the rear fenderwells. While it wasn't damaging to the rear tires, over every speed bump or slight dip in the road you would hear this horrible scraping sound.
My advice to you is what I learned the hard way...if the tires in the front have too much of a offset and may rub on the fenders, grab yourself two flush head screws and replace the two very oversized machine screws in the front fender. the screws on my sedan were on the outer lip at about the 3 o clock position if you are looking straight at the wheel.
those suckers were nasty, and my oversized tires would have lasted longer if I had gotten rid of them sooner.
EDIT: your hatchback may not have the same screws my sedan did, but to be safe, look around the area where the top of the bumper ties in with the fenders sheetmetal, there may be some very large machine screws that will chew your tires up.
Old 03-25-2007, 04:49 PM   #14
spkrman
Drives: 1
I will without a doubt be going over the wheel well with a fine toothed come front and rear. Thx for the info though!
Old 03-25-2007, 04:50 PM   #15
spkrman
Drives: 1
it must be bagged...
yes its required now.
If I *could* i'd drop it just 1", and it would be puuurrrrfect... but it would rub like a trucker at an adult bookstore.
Needs maybe a .5-1" lift while cruising, and 1-2" drop while parked
Old 03-25-2007, 04:51 PM   #16
spkrman
Drives: 1
werd!
who needs to stop when your rims are big enough to just roll over the car in front of you?
Old 03-25-2007, 04:51 PM   #17
spkrman
Drives: 1
as stated above, rubs on full lock and nothing else, its very surprising.
Old 03-25-2007, 04:54 PM   #18
Black Yaris
der Zeck
I would have to totally rework this air system for ya so you can ride higher than stock, I planned to set it up at it's highest point stock and it's lowest point... well as low as I could make it..... and I want to try and get it on and done by Indy Bash, wouldn't that be killer, a bagged blacked out Yaris, a Yaris rollin Dubs, who knows what Chino will be sportin by then, and who ever else comes,all at Indy Bash... killer
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
