Old 06-18-2013, 11:01 PM   #1
Hershey
Question What brake pads and rotors to get ?
Plan to have them replaced by the end of the week . Longevity would be good .
Old 06-19-2013, 10:56 PM   #2
Hershey
Anyone using CENTRIC Premium or NAPA Ultra Premium rotors ? Considering BENDIX CT-3 ceramic pads , any input on those or other ceramic brake pads ? Thanks
Old 06-20-2013, 02:03 PM   #3
mr_miles
Drives: 2013 Yaris
I personally try to stay away from Napa - I have a long ugly history with them. I bought rear shoes from Garm and Jeff (which I think were centric, and I like them), but other than that I have no idea what's good or not since that's all I've had to change so far.
Old 06-20-2013, 02:11 PM   #4
Jason@SportsCar
Centric replacement rotors are great, I use them on the race car. Good quality materials and a reasonable price.
Old 06-20-2013, 02:15 PM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I run Centric rotors and they seem to hold up well. I've had the Centric ceramic pads, they were a touch worse than the stock pads, and definitely don't hold up to heat but they do work pretty well in dirt/gravel conditions.
Old 06-20-2013, 06:12 PM   #6
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I'm running R1 drilled/slotted up front with Hawk pads and Centric shoes in the rear....man that is some stopping power. I have stainless lines waiting, as soon as I stop being a lazy ass I'll throw them on.
All parts are available through MI.
I'm also running ATI Super Blue fluid and speed bleeders all around, those you'll have to source elsewhere.
-Type 07 FFL-
My odometer 03/11
Old 06-20-2013, 06:49 PM   #7
^ good set up, same here
Old 06-20-2013, 07:08 PM   #8
mazilla
advocatus diaboli
mazilla's Avatar
I copied your setup. I figured if it's enough to stop the beast then I'm done with brakes....which is a pretty good feeling considering how relatively inexpensive that all was. It's almost too much stopping power for street use, it takes a little while to get used to. That's one of the reasons I didn't throw the new lines on at the same time, I didn't want to much too soon without time to adjust.
-Type 07 FFL-
My odometer 03/11
Old 06-20-2013, 11:34 PM   #9
Hershey
Thanks for your input . Would've done the CENTRIC rotors and pads but wouldn't get them in time for the appointment . Picked up the NAPA Premium rotors and ceramic pads . They cost $126 with tax , This included a 20% off printable coupon from NAPA , http://www.napaonline.com/Savings/Cu...rcentOffCoupon , this ends June 25th . Used the $100 Debit card to pay for part of them . The debit card was from GM for the purchase of 4 Bridgestone Ecopia 422 tires in early spring . Will consider the CENTRIC in the future . The HAWK caught my attention as well . Will let you know how the NAPA Premium rotor and pads perform .
Old 06-22-2013, 09:39 PM   #10
Hershey
Here's the original rotors with 61,600+ miles and the new ones from NAPA . Labor was $40 . So , $167 total . Forgot to get pics of the pads . The pads had uneven wear on the passenger side with the rotor that has the most rust . The brake fluid reservoir was close to the LOW mark and is now at MAX level with new pads and rotors .
Old 06-22-2013, 10:18 PM   #11
Hershey
Is it possible gas mileage could've been affected with the condition of these rotors ?
Old 06-23-2013, 10:32 AM   #12
09cptn
Drives: 2010 Yaris Sedan
Probably only if they were sticking. Were they badly warped? If they were so badly warped that they occasionally touched the pads without you touching the pedal, then probably, but your gas mileage seems good to me.
09cptn is offline   Reply With Quote
Old 06-24-2013, 11:09 PM   #13
Hershey
We were told they were sticking . Time will tell .
08 Sedan US spec brake rotors and pads. Howardt DIY / Maintenance / Service 1 11-21-2010 05:54 PM
what brake pads & rotors are ideal for me? RacerFreakXXX Performance Modifications 45 06-30-2010 04:28 PM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 10:21 AM
