Old 03-26-2007, 02:02 AM   #1
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Question Side wind handling
I'm a newbee here but didn't find any threads on this.....can someone suggest the best path to follow to improve sidewind handling ....springs/shocks/swaybars? and in which order for most effect as the wallet allows. I've got my MR2 for fun the Yaris is for practical 1st then fun, so lowering may not be best for Minnesota winters. Main problem at 75-80 on I-90 in South Dakota and Minnesota the side winds are almost dangerous!!!!!
churp is offline   Reply With Quote
Old 03-26-2007, 03:07 AM   #2
spkrman
Drives: 1
rims and tires!
I can't imagine anything else helping as much across the board.
Old 03-26-2007, 08:21 AM   #3
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
get low, less wind resistance and keep a firm grip on the wheel
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 03-26-2007, 10:28 AM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
#1-Tires, Tire width helps dramatically so wheels may be needed depending how wide you go. #2-Springs, Springs will keep you car more level when a huge gust wants to push you off the road.
You come into South Dakota? I'm in Rapid City.
Old 03-26-2007, 02:46 PM   #5
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Originally Posted by spkrman View Post
rims and tires!
Agreed! That's what I bought first and I noticed a dramatic improvement. Only on hard winds would I have to fight.
Afterwards I lowered my car and now I don't recall every having to fight with the wind.
Then again I live in sunny California, where heavy winds are rare occassions
eijikikimaru is offline   Reply With Quote
Old 03-26-2007, 02:49 PM   #6
ChinoCharles
Drives: LB
Lower car, stiffer shocks, wider tires. That is pretty much all you can do.
I've got two of the three and I still get blown around, and I'd bet money even with wider tires I'd still blow around on the freeway. It is just something you have to get used to. 2300 pounds and the car sits relatively tall... lots of surface area for wind to put some force on you.
Old 03-26-2007, 02:56 PM   #7
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
If you dont want to lower the car due to obstacles in heavy snow ect, you can still wait for companies like KYB to make a shock for the Yaris. I have runs those on my cars before without lowering and they still help with handling and crosswinds.
You can also use a swaybar and strut tower braces to help stiffen the car up, it helps a little in crasswinds without lowering.
Last but not least, wider tires are where its at! more grip on the road, less bouncing around. When I had oversized turck tires on my 17 rims, my yaris had no problem with the crosswinds everyone on this forum talks about...then I recently got the appropriate sized tires (1.5" less width and about the same less hieght, much less contact patch) and now my car gets thrown about alot,lol.
Lowering is the best way to control this issue, but keep in mind that lowered the car is much more succeptable to damage during those winter months.
Old 03-26-2007, 03:00 PM   #8
ChinoCharles
Drives: LB
Also, keep in mind your car sits higher depending on the rim and profile. If the wind issue really bothers you, get some 15's and 225/40 tires and some springs. That will bring you way down and put a whole lot of rubber on the road.
Old 03-26-2007, 08:15 PM   #9
churp
churp's Avatar
Thanks for the ideas...think I'll try the springs 1st (lower the better just have to watch out for snow), then rear sway bar. Tires will probably be my last change because of snow, ice, and rolling resistance for mileage. Any thoughts on both front and rear bars or is rear enough.
Old 03-26-2007, 08:20 PM   #10
ChinoCharles
Drives: LB
Sway bars.
You could buy a set of shocks with your springs and see way more improvement in suspension rigidity than you would buying a couple sway bars, and the price for TRD shocks or front and rear sway bars is pretty much a wash.
Old 03-26-2007, 08:32 PM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
If she is a daily driver, but you still beat on her, I would go with some tein s-techs (2inch drop) and get yourself some 225/50R15 tires, go with a wheel with a +42 to +45 offset because if you are going that low you will buzz your fenders if you do not tuck that wheel in a bit, drawback being wheel will rub on the inside only on full lock turns.... and the normal stuff upper front and rear way bars, they do make bady stiffeners all the way back for our cars to if you were ever intersted but those are $$$
Old 03-26-2007, 10:54 PM   #12
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
The stock tires have *huge* amounts of sidewall flex, which is probably the #1 culprit. Be midful about just going wider - wider does not always mean a stiffer sidewall. I changed mine to 215/45R17's and the improvement in handling and stability is night and day.
I don't know about US Yarii, but the Thai LB I've got came with a ~1" front swaybar, but nothing on the rear. The front swaybar is actually pretty beefy - it's probably as thick as you'd ever need on sugh a light car.
Razr is offline   Reply With Quote
Old 03-27-2007, 05:33 AM   #13
huh... time to take a look under my car...
Old 03-27-2007, 05:48 AM   #14
Razr
YRS WHOR
Razr's Avatar
Well, you'll need to look under, then up..
Turn your front wheels to full lock and you'll be able to spot the linkages going upward to the struts - at the bottom of the linkage you'll see the swaybar..
Old 03-27-2007, 07:14 AM   #15
Black Yaris
der Zeck
rims and tires!
does not help I have the widest tires you can cram under our cars and don't help one bit, I hope it will get better when I lower it
Old 03-27-2007, 07:31 AM   #16
Razr
YRS WHOR
Razr's Avatar
You have 225/50R15 which means 112.5 mm high sidewalls.
The OEM fitments are:
175/65R14 which has 113.75mm sidewalls, and
185/60R15 which has 111mm sidewalls.
I have 215/45R17 which translates to 96.75mm high sidewalls.
All I can tell you from this is that I don't have a problem
Old 03-27-2007, 07:40 AM   #17
Razr
YRS WHOR
Razr's Avatar
BTW, spkrman has shiny new 225/30R20's - with 67.5mm high sidewalls, I can't imagine him having too many problems with sidewall flex either :P
Old 03-27-2007, 09:44 PM   #18
eijikikimaru
Q(','Q)
Just my luck! After mentioning that it doesn't get so windy here in So. CAL today was a windy day. Gust up to...what does weather.com say...up to 28 mph.
Is that a lot??? Anyways my car didn't get pushed around. Unlike before when the car was stock, I'd probably look a flipped turtle if I was still stock
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 03:40 AM
sedan handling sucks punch Performance Modifications 16 09-29-2006 10:26 AM
