Old 07-02-2013, 12:34 PM   #1
galactic7gecko
Drives: Toyota Yaris
Yaris will not accelerate
Howdy Guys/Gals,
I have a 2007 Yaris 3 dr. approximiately 85000-90000 miles on the odo.
This morning while driving to work I experienced a loss of acceleration. I pressed the accelerator down to the floor several times to no avail. However I did notice that upon SLOWLY pressing the accelerator I could come back up to speed. I ended up making it to work but the problem persists. There is no way I can make it up the freeway ramp with sufficient speed to meet traffic.
Does anybody have any ideas on what could have happened or what kind of problem this may be?
Thanks for your help.
galactic7gecko is offline   Reply With Quote
Old 07-02-2013, 01:13 PM   #2
7:34pm
Drives: 07 Yaris
Sounds like your clutch is worn/slipping.
7:34pm is offline   Reply With Quote
Old 07-02-2013, 06:52 PM   #3
galactic7gecko
It's automatic would that still be applicable?
Old 07-02-2013, 07:06 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
With a automatic it may be the torque converter. Have you checked your transmission fluid? Also the Yaris uses special toyota ATF which you can get online or at the dealer.
Old 07-02-2013, 07:34 PM   #5
galactic7gecko
The level is above the two notches so I believe the transmission fluid is ok. How do you check on the torque converter?
I have a scan gauge II can that help me diagnose the problem in any way? I have already scanned for codes and there were none noted.
Old 07-03-2013, 07:42 AM   #6
DonM
Drives: 2008 Yaris sedan, 5 speed
Guessing that you might have a clogged fuel filter
DonM is offline   Reply With Quote
Old 07-03-2013, 10:02 AM   #7
barryware
The OP needs to explain just a bit more..
Is it the engine that will not accelerate when pressing on the throttle or does the engine rev but the car does not pick up speed.
If the engine revs but the car does not pick up speed, then the transmission would be suspect.
If the engine does not increase rpm when the throttle is depressed, then one of the engine control systems needs to be diagnosed.
barryware is offline   Reply With Quote
Old 07-03-2013, 10:54 AM   #8
YarisSedan
Drives: 08 Yaris Sedan
Maybe mass air flow sensor
Old 07-03-2013, 11:21 AM   #9
RedRide
RedRide's Avatar
I agree, it could be a dirty MAFS if it only involves the engine.... a somewhat common overlooked problem.
With 90,000 miles, it could indeed be dirty.
http://youtu.be/_TO7ZC5N-aA
Old 07-03-2013, 12:09 PM   #10
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
Is the car throwing an engine code???
you can check the RPMs with the scangauge along with open/closed loop. I think that will tell you more about what is going on.
if your fuel filter is clogged, that is an SOB there.
I would check the RPMs to make sure it isn't trans related and if it isn't, change air filter and clean the MAF. also clean the throttle body while you're at it (actually not a bad idea to do regardless).
good luck
Old 07-07-2013, 06:39 PM   #11
galactic7gecko
Hey Guys! Thanks for all the advice. It turns out it was an electrical short. About 6 months ago someone stole my radio and severed the wiring harness that connects the radio. I took it to the dealership to have it troubleshot and they said they found a loose wire that was causing all the problems. They reattached the wire and apparently all is running well so far...
Thanks again for all the good ideas.
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
