Old 07-03-2013, 12:43 AM   #1
YAR1S
YAR1S's Avatar
Silly question ..... >.>
I know I can probably search this but I havnt posted up a thread in a while....
my car is well over 125k and well ....
what major service is it in need of?
I'm assuming the dreaded timing chain....
perhaps a transmission/coolant flush as Ive never had it done.
I feel so bad for my yaris... I feel like I've neglected all it's service needs....
except I have been very good and given it full syn oil changes on schedule every 5k.
Thanks for not flaming at me....
-Jen <3
Old 07-03-2013, 01:13 AM   #2
cutie patuti
cutie patuti's Avatar
Drives: 2011 Yaris Y
replace oil,filters,spark plugs
cutie patuti is offline   Reply With Quote
Old 07-03-2013, 01:24 AM   #3
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
+1 replace trans/gear oil/ and coolant, maybe brake fluid and or pads if needed
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed
Yaris T-Sport is offline   Reply With Quote
Old 07-03-2013, 09:23 AM   #4
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
The Yaris has a timing chain, not a belt like some other models. No need to change it.
Other than that, like others have stated, fluids, filters and plugs. That is about it.
The Yaris does not require much in the way of scheduled maintenance and most of it can be done by the owner.
2007 LB W/Cold Wx Package
DMZ is offline   Reply With Quote
Old 07-03-2013, 10:04 AM   #5
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
Timing chains need to be replaced when they are worn. Usually you can hear if they are worn. There is a lot of clanking and what not. There is probably a schedule for that but I think our engines are non-interference motors anyway so if the chain lets loose, it won't hurt anything anyway (feel free to correct me as that would be good to know).
I know a guy that had a dodge dakota with 600,000+ miles on it with the original timing chain. He had a courier service.
Old 07-03-2013, 01:03 PM   #6
RedRide
RedRide's Avatar
As long as you change the oil regularly, the timing chain should basically last the life of the car.
A certain amount of play in the chain is normal for it to still be in spec.
The "1NZ-FE" is indeed a non-interference engine as are most of Toyota's engines.
Old 07-03-2013, 02:33 PM   #7
esse10
Drives: 2009 yaris 2 door
timing chain
If you have 125k and never done any repairs you're doing goooood.
Tranny fluid and coolant flush sound about all you need to do for now and Have somebody check your ball joints,tie rod ends and shocks/struts to see if they need replacement. Do a front end alignment and sometimes those mechanics will inspect all your suspension and let you know what needs replacement. Have a brake shop inspect your brakes, especially the rear cause I believe those wear out faster on these front wheel drive cars. Good luck to ya
I believe the timing chain is not due for replacement until 400-500k miles.
and if you're conscientious about getting stranded I would replace the serpintene belt and battery if they are already 3-4 years old.
Old 07-03-2013, 03:46 PM   #8
RedRide
RedRide's Avatar
Yes, I would definitely check/replace the serpentine belt if you haven't replaced it recently.
Although it wont cause any damage it it breaks, it will leave you "dead in the water" if it does .
silly spark plug question ryota DIY / Maintenance / Service 11 08-25-2013 11:41 PM
Silly question? Does running higher PSI cause more wear-and-tear on suspension? matti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-28-2012 08:42 PM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
Silly Question Nutzoids General Yaris / Vitz Discussion 2 05-15-2007 01:38 PM
