Old 07-07-2013, 05:57 AM   #1
09sedan
Drives: 2009 yaris sedan
LPG conversion on a 2009 Sedan
thinking about doing a LPG conversion on my 09 sedan, looking at the direct injection system they have now for gasoline engines, ( it will likely be a duel fuel setup where i can switch whenever i want between gas and LPG) still waiting on my quote from a shop in toronto, anyone else do a LPG conversion before?
09sedan is offline   Reply With Quote
Old 12-10-2013, 04:36 PM   #2
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I would think one or the other, not both. Engines would have different needs, lpg compression comes to mind, then of course delivery methods.
Old 12-12-2013, 07:31 AM   #3
MileyRickens
Drives: MileyRickens mini van
Send a message via AIM to MileyRickens
Usually you cannot do a conversion for cars before 2005 models. So what year is your model?
best buy vacuum cleaners
MileyRickens is offline   Reply With Quote
Old 12-15-2013, 12:09 PM   #4
^ his username is 09sedan! I've seen dual setups, but not on a Yaris.
Good luck with your project, post up your progress!
2009 yaris sedan s (ipod/aux) speaker change cleargrip DIY / Maintenance / Service 4 10-30-2012 09:24 PM
new Yaris 2009 sedan, 1 month old - problems already? rirakuma717 DIY / Maintenance / Service 10 04-13-2011 12:00 AM
lpg conversion parkincake Fuel Economy Forum 3 12-02-2010 10:39 AM
