Old 07-09-2013, 05:54 PM   #1
mrbond
mrbond's Avatar
Questions for new flywheel and clutch
I am getting ready to install a new clutch and a Fidanza flywheel in a few weeks and I have a couple of questions that I could not find either on these forums or pretty much anywhere else. I got the flywheel on eBay almost two months ago, and though it's a new and unused unit, it did not come with any bolts or fasteners - just the flywheel, the installation instructions, and a big sticker. I had read on Honda forums that you're supposed to install new flywheel bolts, but the factory service manual doesn't say anything about replacing the flywheel bolts.
So. First question: do I or do I not replace the flywheel bolts? Second question: since I'm not sure if the 1nz flywheel from Fidanza came with any bolts or fasteners for the pressure plate, do I reuse the pressure plate bolts or is the thread pitch on the Fidanza different from the stock flywheel? Last question: for those who have installed a Fidanza unit on their Yaris themselves (not taking the car to a shop to have it installed), do any of you have tips or suggestions that would help make the installation process smoother and less frustrating?
Thanks in advance
- A Toyota Yaris
- A whut Yaris?
Old 07-09-2013, 06:49 PM   #2
Which clutch?
Make sure they mate properly. Any surfacing instructions with it?
They don't come with hardware. Are the flywheel bolts "torque" or "torque to yield"? If the latter, you can't re-use them (stretch bolts).
Old 07-09-2013, 07:21 PM   #3
mrbond
mrbond's Avatar
It's the TRD clutch shown on TRDSparks and other sites. The Fidanza instructions don't say anything about surfacing, just that it's recommended but not required to have it balanced. The clutch itself and the pressure plate appear to mate to the flywheels just fine, although the pressure plate sits about 1/8 - 1/4 inch above the flywheel when I mock it up. From what I've read, this is normal as the pressure plate bolts will, when torqued in the proper sequence, mate the pressure plate flat to the flywheel. The service manual says to torque the pressure plate bolts, and "torque to yield" isn't present anywhere in the clutch chapter, so I assume these bolts can be reused. The flywheel bolts in the manuals say "torque to 90 ft/lbs, then turn 90 degrees" so I assume these are torque to yield and must be replaced?
Also, I have the manual transmission seal/gasket set from Toyota (P/N 04331-52520). Besides these seals, is it recommended that I need any other gaskets/seals?
- A Toyota Yaris
- A whut Yaris?
Old 07-10-2013, 04:51 PM   #4
mrbond
mrbond's Avatar
Bump.
Anyone ever replaced their flywheel and pressure plate here?
- A Toyota Yaris
- A whut Yaris?
Old 07-10-2013, 05:16 PM   #5
Radou
Radou's Avatar
Drives: yaris 09 ncp91
the pressure plate bolts are re-usable and you need brand new flywheel bolt from toyota like the manual shop said
Radou is offline   Reply With Quote
Old 07-10-2013, 05:32 PM   #6
mrbond
mrbond's Avatar
Then I just need new flywheel bolts. About the seals/gaskets: though I have the Toyota manual "transmission overhaul" gasket set, do I need a rear main seal or can it be reused on these cars?
- A Toyota Yaris
- A whut Yaris?
Old 07-10-2013, 05:50 PM   #7
I always use new gaskets. What if you re-use one and it leaks?
Snarky comment!
Old 07-10-2013, 05:54 PM   #8
mrbond
mrbond's Avatar
Ooooh, in what way was that snarky?? I don't know of hardly any Yaris owners that have upgraded their clutch and flywheel at the same time, which is why I started this thread in the first place. It was just a very simple and straightforward question.
- A Toyota Yaris
- A whut Yaris?
Old 07-10-2013, 05:55 PM   #9
Radou
Radou's Avatar
and yeah you need to change de seal :p
Old 07-10-2013, 05:56 PM   #10
mrbond
mrbond's Avatar
Alright, awesome. That's all I needed to know. Thanks!
- A Toyota Yaris
- A whut Yaris?
Old 07-10-2013, 11:45 PM   #11
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Ive changed my clutch in my tercel several times...still on the original hardware...however is that proper? I have no idea. I reused the bolts when I went to an aluminum flywheel as wheel
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-11-2013, 07:17 AM   #12
thefalls
Drives: Axio GT
As TRD states, when buying their lightened flywheel,you need to buy new flywheel bolts.
thefalls is offline   Reply With Quote
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch question. Black_griffin6 Performance Modifications 6 04-04-2013 04:30 PM
Clutch & Flywheel Installation help Needed. victorddr DIY / Maintenance / Service 9 01-10-2011 12:09 PM
Clutch getting replaced; questions Thirty-Nine DIY / Maintenance / Service 39 01-19-2010 10:22 PM
Thinking about flywheel & clutch... MGargano Performance Modifications 10 09-13-2009 12:11 AM
