Old 07-13-2013, 12:07 PM   #1
2007yariz
Drives: Yaris sedan
Does this look normal? Under radiator cap w/pics
I unscrewed the radiator cap off my 2007 Toyota Yaris. Yesterday, while in stop and go traffic with ac on, the high coolant temperature warning light came on! So it led me to check it.
Does it look normal, should I take it to a Toyota Dealership to check?
2007yariz is offline   Reply With Quote
Old 07-13-2013, 01:34 PM   #2
esse10
Drives: 2009 yaris 2 door
coolant
The coolant reservoir looks normal, the hose level looks a little low you need to top it off all the way to the top to avoid air getting in there when you put the cap back on. If you don't have a temperature gauge I would get a smart phone application along with one of those wireless elm-327 and monitor that coolant temperature real close to see if in fact the engine is getting too hot or just a computer glitch. Have you seen any small coolant leaks on your driveway in the last few days? particularly where the water pump is? The water pump usually start leaking a few days before it completely fails. check the water pumps weep hole and if you see any signs of coolant replace the pump immediately before it leaves you stranded. Good luck to ya
fyi-you can get the elm327 on ebay for $20 and the iphone app for $5
Old 07-13-2013, 06:29 PM   #3
2007yariz
Drives: Yaris sedan
Thanks for the reply, but no leaks on the drive way
Old 07-14-2013, 08:02 AM   #4
BLH
Drives: 2007 Yaris Sedan
After my water pump was replaced in warranty.
Some trapped air showed up. Like in your photos and the reservoir was full to max hot.
I added some coolant to the radiator and now all is fine.
Old 07-15-2013, 01:06 PM   #5
jcboy
Drives: Sedan 07
in addition, get a new Radiator cap. it might fix the problem together with bleeding air out of your system.
Normal or not normal? Septembersrain Third Gen Yaris General Discussion 7 05-27-2013 12:50 PM
Smoke smell question. Is this normal? Ilovemyyaris DIY / Maintenance / Service 6 08-10-2012 02:04 PM
Transmission sounds, what is normal ? Yaris17 DIY / Maintenance / Service 3 11-20-2011 07:00 AM
How much engine vibration is normal? Frankd1 DIY / Maintenance / Service 6 10-14-2009 09:11 PM
Is This Normal? i was told its normal, but i dont think it is jthebeh DIY / Maintenance / Service 3 11-27-2006 08:46 AM
