#1 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
Rav4 Trans issue
Ok, I got a 2002 Rav4 automatic
Code came up. Shift Solenoid B malfunction. Now, I know that these are interchangeable and I am hoping maybe this will fix the issue with this Rav4. Its having some shifting issues between 1 and 2. What I need is a good diagram of the solenoids when you pull off the transmission filter. They all look the same and not sure which is A, B, or C. Anyone able to point in the right direction?
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
need some quick help with advice
http://www.villagetoyotaparts.com/sh...ssembly=351007 here is a list of valve body parts and solenoids. which solenoid is the "B' that I need to replace. If I have to buy all the "B's" I will. At less than $5 ea. I dont mind doing that. Will sure beat buying a new tranny.
| Air Conditioner Noise & Leak? | Dawn Eshelman | DIY / Maintenance / Service | 116 | 07-21-2015 01:22 PM |
| Rav4 Trans | ilikerice | Willing to Buy by private party | 2 | 07-02-2013 08:18 PM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 04:20 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
