Old 03-27-2007, 06:44 PM   #1
majorposer
Drives: purchasing
competition seat harnesses
I work at a MINI cooper dealership, and let me be the first to say how easy they have it when it comes to aftermarket. everything is laid out for them. i've installed a couple clip-in harnesses for customers, and i was really impressed. Now i know the proper way to install a harness, and if it takes me to drill holes into the floor, i'll do it. But does anyone have simple set-up?
majorposer is offline   Reply With Quote
Old 03-28-2007, 08:21 AM   #2
punch
punch's Avatar
yep, you need a roll bar
Old 03-29-2007, 06:17 PM   #3
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Use the back seat seatbelt bolts . Safe-Quip has an easy to remove/apply plate that will attach to your rear seatbelt bolts . Their Harnesses are the best . The have old style (latch) and new style (quick release hubs) . In any color you want . They will even sew patches on if you ask . They are right down the street from me . They have a bunch of very experienced "Young" :) ladies that sew the belts .
Old 03-29-2007, 06:27 PM   #4
majorposer
Drives: purchasing
See my problem i run into is not the shoulder belts, but the lower two belts. there isn't anything behind the seat to mount too with out drilling.
Old 03-29-2007, 06:30 PM   #5
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
use the car seatbelt mounts or the seat mount bracket bolts
also there should be 3 or 4 lower belts not 2
Old 03-29-2007, 06:41 PM   #6
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
well, if you are going to autoX, maybe I am wrong, but are safety harnesses allowed to be screwed into the floorboards? I was thinking that for a full harness and to be approved they needed to be hooked to a rollcage...thats just my lack of info comming from my ass though, I am 'prolly completely wrong.
Old 03-29-2007, 07:42 PM   #7
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Im sure it should be stated very clearly where and how the harness mounts in the SCCA rules for each class.
jdubau55 is offline   Reply With Quote
Old 03-30-2007, 10:26 AM   #8
The way mine are mounted are probably against any regulations, but it gets the job done quite well without a roll cage (yet)
Old 03-30-2007, 10:30 AM   #9
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
That will really screw you up if you get hit from the side or rear. That configruation is highly dangerous.
Old 03-30-2007, 10:37 AM   #10
Yeah that's what I thought too, but I rarely even use the harness nowadays, the regular seatbelt is still fine, and it gets rid of that annoying flashing reminder light.
I will eventually get a roll cage and will be sure to have the harness redone properly
Old 03-30-2007, 10:42 AM   #11
largeorangefont
Break'em off some.
Well if you dont use them its ok then.
Get a harness bar made in the mean time. It should be pretty simple for a shop to design and weld one up for you. Then you can use the harnesses and it will be safer.
Old 03-30-2007, 06:38 PM   #12
majorposer
Drives: purchasing
well, i've been through the rule books before on a previous car. there are loops between the rear seatback and seat bottom that i can clip into. it's a little less than a 45 degree angle, which is legal. i can mount too the sheet metal, but i need to use approved backing plates to disperse force better than a nut and washer. Your also not allowed to mount to the seat. i'll have to see about getting some brackets made to use the seat track mounting points.
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
How to install seat covers that require... IsLNdbOi Cosmetic Modifications (Exterior/Interior) 13 09-23-2007 07:57 AM
back seat KSIbucky General Yaris / Vitz Discussion 10 05-30-2006 12:54 PM
Liftback seat question Goose General Yaris / Vitz Discussion 6 04-21-2006 12:29 PM
