Old 07-19-2013, 03:36 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Hooking LEDs to the dimmer switch, any problem?
Will there be any problem if I hook up LEDs to the dimmer switch?? Does the current light such as the center console knob gets dimmer because of the extra draw?
Judging from this from CTScott
10 Pin connector D29
Pin 1 - N/C
Pin 2 - Light Green: Output to radio, AC lights, etc
Pin 3 - White/Black: Ground
Pin 4 - N/C
Pin 5 - Brown: Power in from PANEL1 fuse
Pin 6 - N/C
Pin 7 - N/C
Pin 8 - Yellow: Output to Cluster
Pin 9 - Orange: Output to Hazard warning signal switch and Door lock switch
Pin 10 - Sky Blue: Power in from GAUGE Fuse (Ignition switched)
Should I tap the light green wire to power my LEDs?
Thanks
caineroad is offline   Reply With Quote
Old 07-19-2013, 03:53 PM   #2
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
You'd have to hook up quite a bit of LEDs to cause anything to dim. I've got 8 LED strips running off the door-open circuit and nothing is any dimmer than it was before.
Old 07-19-2013, 04:25 PM   #3
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
From what I recall seeing here and there tapping that dimmer is a no-go...seems to be responsible for problems most of the time. Don't quote me on that however.
-Type 07 FFL-
My odometer 03/11
Old 07-19-2013, 06:30 PM   #4
caineroad
caineroad's Avatar
i see
Old 07-19-2013, 06:38 PM   #5
caineroad
caineroad's Avatar
i am just thinking though if there is any wire I can connect to that is wire with the dimmer switch, i can tap that for easy access, cuz I plan to install the LEDs in the rear as foot well lightning.
Old 07-23-2013, 02:01 PM   #6
jcboy
Drives: Sedan 07
lucky for me i'm using the foglight switch illumination wire. our dimmer switches are located under the hazard button, and is only for the gauge.
i used that to wire up the door lock switch (center console, we don't have it here) so if it's any help, look for the wires that illuminate your switch (US/CA models usually have this switch) and wire from there.
Old 07-24-2013, 03:26 PM   #7
johnbob
johnbob's Avatar
I used the wire off the radio (green radio illumination wire off back of radio) my problem is I shorted this wire and while I replaced fuse and got power back, I no longer have dash or speedo illumination once I turn on parking light switch. Lights on dash on when parking switch off / off when parking light switch on. Anyone aware of a relay for dim/bright function of dash lights that perhaps I knocked out?
johnbob is offline   Reply With Quote
Old 07-24-2013, 03:50 PM   #8
caineroad
caineroad's Avatar
So you have replaced PANEL1 fuse, radio lights work when you turn headlights on but speedo and dash are dark? Does the speedo lit up when you turn off headlight?
If u have dimmer switch make sure its functioning properly
Old 07-24-2013, 04:04 PM   #9
johnbob
johnbob's Avatar
Speedo does light up when headlight switch is in off position.
Fuse it blew was 7.5a for panel lights. Fuse replaced.....wait a minute
Damn dude your genius, must have rolled the dimmer down by mistake in process of replacing fuse. Not usually ham-handed doing repair and wiring work. Problem was kicking my butt because I was reading voltage at radio wire. Thank you for the suggestion/problem solve.
Old 08-21-2013, 02:43 PM   #10
caineroad
caineroad's Avatar
Just wanna update if anyone is doing dimmer in the future,
I have found a way at least for me it works the best is to tap into the AT shift light both the positive and negative wire, I have since connected 4 Leds to it without problem. It's easy and convenient. dim-able with the dimmer switch
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
F/S Dash Light Dimmer Switch 1NZYaris1 Items for Sale by private party 4 09-26-2012 03:55 AM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
Dimmer Switch Question sroberts General Yaris / Vitz Discussion 3 10-16-2006 10:51 AM
