Old 07-20-2013, 08:54 PM   #1
ApolloJA
Drives: Vitz RS
Exclamation Side Marker Light Issue. HELP!
So i decided to place in the bulb and socket in the side marker (city lights/park light) but it doesn't light up the entire strip which i know it should. Is it because the bulb may be too short or what?
ApolloJA is offline   Reply With Quote
Old 07-20-2013, 09:15 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
It should only light the bulb which it shows in the picture.
It doesn't light the entire orange reflector.
Old 07-21-2013, 07:10 PM   #3
ApolloJA
Drives: Vitz RS
even if it isnt suppose to light up the whole reflector, im sure it is suppose to cover a lil more. Like this for example
Old 07-22-2013, 01:18 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Did you replace it with another (regular) filament bulb or did you replace it with an LED replacement?
Old 07-22-2013, 05:32 PM   #5
jcboy
Drives: Sedan 07
^+1. LEDs have directional illumination. light is not spread out as compared to filament (normal) bulbs.
Old 07-22-2013, 07:58 PM   #6
ApolloJA
Drives: Vitz RS
i put in LEDs. So thats the issue? guess i should replace it with the normal bulb then
Old 07-22-2013, 10:52 PM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
The LEDs you installed will not be as bright as your filament bulb.
Reinstall you original bulb to get that brightness you wanted.
bulb, headlight, leds, light, parking light
JDM Vitz RS Side Mirror with LED Signal Light AlainMikli Cosmetic Modifications (Exterior/Interior) 35 11-18-2013 08:47 AM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
HELP: New passenger side rear light rubber seal needed kavos wildcat DIY / Maintenance / Service 5 12-16-2012 05:38 PM
LED Fog light blinking issue BruceLee DIY / Maintenance / Service 20 12-01-2012 09:41 PM
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
