Old 07-25-2013, 03:18 PM   #1
Persi
Persi's Avatar
Drives: 2008 Toyota Yaris
Question Changing cabin air filter, help!
Hi there!
I know this is something pretty easy to do, but I think I'm simply overthinking things so I figured I'll ask for some help before I install things incorrectly.
As you can see in the pictures, one tells me UP with an upward arrow (in the car) and on the filter it says Air Flow with a down arrow. Should I be matching up the arrows to go in the same direction or opposite?
Thanks!
Persi is offline   Reply With Quote
Old 07-25-2013, 04:19 PM   #2
sex
sex's Avatar
Drives: 09 5DR
Air should flow from top to bottom in the case. Your filter should be installed with the arrow pointing down
Old 07-25-2013, 05:37 PM   #3
RedRide
RedRide's Avatar
Edit... sex is correct
Old 07-25-2013, 05:54 PM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Sorry RedRide - you're wrong (or your blower is wired backwards.)
I just tested it - airflow is clearly from top to bottom. When I pulled my filter, all of the debris is on the TOP.
That bellows, when down, sucks air from the vents on the exterior cowl.
Old 07-25-2013, 06:01 PM   #5
RedRide
RedRide's Avatar
My apologizes. You are correct. I was thinking of a different car ...sorry
Old 07-25-2013, 06:06 PM   #6
Persi
Persi's Avatar
Thank you for all the input! I checked out the airflow directionality just in case and it is from top to bottom. My filter is now in and it all makes a lot more sense now!
Thanks again!
Old 08-09-2013, 08:50 PM   #7
rapev-8
Drives: toyota
so does the arrows on the filter point it up or down?
rapev-8 is offline   Reply With Quote
Old 08-09-2013, 09:23 PM   #8
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
The blower fan sucks from below , that means the arrows should point downward.
Mittelklasse is offline   Reply With Quote
Old 08-09-2013, 09:52 PM   #9
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
ok, I went through this two years ago, I bought a puralator cabin filter from a local auto parts store and paid half what the dealer wanted, compaired them and they were exacltly the same. Anyway, it took a piece of toilet paper for me to figure out air flow and the arrows on the puralotor were pointing to airflow, but the toyota filters arrrows were backward. go figure
Why didn't the Yaris come with air cabin filter? detroiter DIY / Maintenance / Service 19 11-21-2012 05:42 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
cabin air filter kaboom DIY / Maintenance / Service 108 03-31-2009 09:00 PM
CA: Free Cabin Air Filter, Socal only. kunfuzion Items for Sale by private party 6 03-24-2007 11:34 PM
