Old 07-27-2013, 10:56 PM   #1
Misfit
2012 sedan no cruise... needs it.
Does the 2012 sedan have a cruise control option? I was hoping to add cruise control the same way other people have suggested, i.e. simply adding the stem through the side and attaching the wires; hoping that the cruise option wiring was already in place. Am I out of luck with the simple install?
Thanks
Marv
Misfit is offline   Reply With Quote
Old 07-27-2013, 11:15 PM   #2
Yes - It is the same as for the 2006-2011 Sedan. If you have power windows and lock then all of the wiring is in place. If you do not, then you will need to run one wire from the ECM to the steering column (the pin will be in place in the ECM, but the wire is not connected from point A to B).
See my DIY for the details.
Old 07-27-2013, 11:28 PM   #3
Misfit
Yes, it has power locks and windows.
Now, My son-in -law says I should be able to buy the cruise parts (stem lever, and simple wire attachment) for about $50. All I can find are kits for $175 to $200. Any ideas of what I need? Thanks for the great help.
Marv
Old 07-27-2013, 11:59 PM   #4
All you will need is the stalk with the harness and mounting screws.
Old 09-20-2013, 08:57 AM   #5
Max Thompson
Drives: 2012 Yaris
2012 Cruise control
Do you have these parts? If not what is the price from Toyota?
Max
Max Thompson is offline   Reply With Quote
Old 09-20-2013, 09:09 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Max
See Scott's DIY as previously noted:
Cruise Control DIY
Old 09-20-2013, 02:55 PM   #7
You can get the parts from MicroImage. Not sure if they are 2012+ compatible though.
Old 09-20-2013, 04:19 PM   #8
Yes. 2006 - 2014 all use the same parts.
Yaris 2012 Sedan faisalloe New YARIS Purchase Forum 0 09-27-2012 03:05 PM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
